Pages: [1] 2 3 ... 5   Go Down
Author Topic: english version: tuto for the creation of great quality synopsis with YADIS!  (Read 17290 times)
zaimben13
i love mede8er ! big up for south africa!
« on: August 29, 2010, 09:20:18 pm »
/ All : YADIS IS FREE AND IT WILL ALWAyS BE!!!!!!
    v. 2.2 is out now!!!!!
hello guys! Smiley here is a brand new post with the step by step tutorial to create beautiful synopsis with a software called yadis!!!
warning!!!!!!:with v2.0.0 and 2.0.1: do not modify the  setup  window, DO NOT MODYFY THE DIRECTORY OT THE YADIS WORKSPACE or   the "dune interface location" or it will rase all your filmmmmm!!!!!!! i got no responsabilty in any problem if you modify the workspace destination or dune  interface!!
but please , note that since yadis 2.0.2 yadis create automaticaly (if you modify the dune interface location) a sub folder called    _yadis ,if the directory where you want to put yadis interface contains media file ...so theres no risk of delet of files! but take care!
so here is the step by step tuto:
1/first of all:  download and install this software  called "YADIS" :link to the software here
 http://yadis.whisperingvault.net/projects/yadis    version 2.1.2   !!!!!!!!!!!!!!
the software is compatible with english, french, german, spanish and italian languages and much more ! synopsis will be in the languages you choosed  by settings it in the main windows
( actually: only french, english, deutch and nederland synopsis)! (connection to french, english,deutch and nederland database!
2)- try to learn the basic of yadis by reading the pdf  guide you'll find on the official site, but be careful, you are concerned by the pdf only for a small part!
3)- when you get familiare with the creating process which is not compicated(  in the set up menu , choose first, the language you want yadis to be used... this option just translate the soft in the language choosen!
4)-then , choose  when yadis restart, in english now....or other language, click again setup button, and in the windows, in the "profil" section, " choose med500, click the "videowall button if you want yadis create folder and about jpg to be used in videowall, or dont click if you are not using videowall view but the older one, the "simple view " anyway, if you just used the ab or slow button.....   , choose the directory where  your film are...click ok!
5)- then yadis has now find your directory with all you film and series that appears in the small window at the left,
6)-the creating process can began!
7)-select your films ( try to choose maximum 20 films per 20 film) when selected your film that appear now in blue (max 20 so you sure theres no bug (the last version (1.3 has this kind of limit)   click  "process button"!
Cool -yadis start automaticaly to search for jacket (folder jpg) ans synopsis (about jpg) trough the net , note that if you choose english it will search in the english database "tvdb" an alternative to imdb. you can also create deutch and nederland synopsis....
9)- please, try to have all your films , each film correctly named if possble and in each folder (even if now, yadis can create synopsis if your film are not in  folder  for each of them! and if you can manualy searched a film that yadis havent find in the database (its your fault  most of the time trust me... ex: the  title is not correctly  writen for exemple).
10)- the  process can take 2 or 3 min for 20 film  even less time!
11)- when yadis succeed in the search, all your films at the left appeared in blue with a blue icon that means ok!
you can now by choosing a film in the list , manualy changed the folder jpg, about jpg  , just go  to the button at the bottom of  the window called " cover" and " fanart" choose the image you prefere but you can also let the synopsis as yadis created it if its enough beautiful to your eyes!
12)-you can also edit manualy the media information:  go to media button , modify if you want!(realy useful if yadis  failed to recognised the information of your media but 99 pourcent of time it will be ok you'll not have to modify manualy!
you can also modify the film info  manualy , go to movie buton, etc....
13)- if yadis failed to find information about one of your film,  you can easily find it manualy!! : click the "change buton" in the right botom of window... write corectly the name of the film...  ok....yadis will propose you a film click the one coresponding to your search!
14)-when all your  synopsis have been created,  the manually part of the old tutorial is now the past,  yadis has created all your folder and about jpg, with a correct  name and size to be used properly in video wall!!!!!! or with the old technique ( a/b or slow button) so just close yadis and power on your med and unleash the power of it now!
all my 180 film in the internal hdd of med500 are linked in videowall all folder and about are welll linked and recognised by the med videowall! thank to yadis 2.1 , no more fastidiioud manual process !(naming and resizing is automatic now!)
17)-the finale result is  exactly the same of  what  the  owners of dune mediaplayer can profit on their dunes, with the  yadis interface in less of course. and in my opinion, I think that the jackets created with YADIS ARE  more beautiful than THOSE CREATED WITH tvixie...regarding the quality of the synopsis!
SO I HOPE THAT THIS LITTLE " french astuce from zaimben"  WILL BE USEFUL TO YOU! good work and good day. ps: it on ly took me 2  hours to  rescan  my 180 film in internal hdd  (aproxymatly 408 films...)
EDIT: sometime, yadis will encounter difficulty to find the info related to  a film , in this case, try to modify the title of the film by using the  "reload information button "  go on the main window of yadis in which you created the synopsis, right click "reload information" try to write the right name of the film , and do a manuallly search, in most of case 99pourcent) yadis will find what you want!!!!!
you can see the exemple of synopsis you can create with this wonderful softaware in my previous post on those topics:
-Firmware release discussion > New firmware upgrade? page 18 down of the page (the poursuit of happyness)
-Graphics Downloads > Post your about.jpg [YAMJ Generated] fanart here ! page 2  (down of the page to  page 4 )!
zaimben!
« Last Edit: August 10, 2012, 05:42:18 am by zaimben13 » Logged
med500x firmware 4.0.4 2to hdd inside +2to external hdd
ps3 slim 250go
xbox 360 elite SLIM  250go
 lcd  LG 27 inch full hd
waiting for  MED1000X3D  release in Europe
« Reply #1 on: August 29, 2010, 11:51:43 pm »
Hi zaimben13,
I tried the Dutch language setting.
It turns alle the things in the program to Dutch, but still the movie plots are in English language.
With YAMJ it is possible to create Dutch plots by pointing it to http://www.moviemeter.nl/, same with Tvixie.
Not with YADIS at the moment.
zaimben13
« Reply #2 on: August 31, 2010, 08:39:32 am »
hi maassbomel!
yeah, i see what you mean, actually the  software is only capable to generate synopsis in french and english,  there is a version 2 of the soft which is going to be released by the  guy who created it... this v2 will be able to generate deutch and nederland synopsis by using a new database (one in deutxhland the other one......
italian and spanish are also on the line.... i will come back here to  warn the community when the new version will be released !
also: the creator of the software is interested  with the idea to  fully adapt  it on the med500 ! he want to know more about the abilyty of the med to accept third party plugin software ! can you give me more info? is the box capable (or will it be? when yamj...will arrive)of accepting other soft than yamj ?
« Last Edit: September 02, 2010, 05:14:37 pm by zaimben13 » Logged
ps3 slim 250go
C00per
« Reply #3 on: September 01, 2010, 02:36:38 pm »
Thanks but not supported on Windows 7  Embarrassed
Edit: Ok it's solved for those who have an OCX error during the installation, you should install Visual C++ 2008 Redistributable Package.
C++ 2008 Redistributable Package (x64)
http://www.microsoft.com/downloads/details.aspx?familyid=BA9257CA-337F-4B40-8C14-157CFDFFEE4E
Visual C++ 2008 Redistributable Package (x86)
http://www.microsoft.com/downloads/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2
« Last Edit: September 01, 2010, 03:12:10 pm by C00per » Logged
zaimben13
« Reply #4 on: September 01, 2010, 04:38:29 pm »
hi cooper!!!!!
so how do you find yadis?  isn't it a cool software huh.?. if you have any probleme juste ask.....
ps: for the moment, yadis is capable of generate french and english synopsis! ohter languages are comming soon in the v2 version: but NO PRECISE DATE CAN BE GIVEN BY THE DEVS!!! :)patience...
« Last Edit: September 02, 2010, 05:13:01 pm by zaimben13 » Logged
ps3 slim 250go
C00per
« Reply #5 on: September 02, 2010, 11:57:26 am »
Hi zaimben13,
I can't believe in the perfect tool that can
scan/rename/get pics/get synopsis/create folders/and move files to the nmt's and keep them up to date but this one is the best approach I have found  Cheesy
Thank you for this one ;-)
- First I had to map my nmt drive.
- Second clean my files name with a free renamer (remove team tags,Descriptions etc...).
- List my files in a dos prompt (because I have no folders at all Grin).
- Copy the list in a txt file and with the help of this tool Text2Folders launch the folders creation.
- Start the scan (apparently based on the folder list and not directly on the nmt drive with the movies, we never know Wink.... it's really fast but I have 2 remarks...
>I just noticed that if the movie is not present in the source folder during the scan, only few files are created without the synopsis. I tried by adding a fake movie file inside one of the folder and after another scan more files were created with synopsis etc...
I mean it's not possible to use the tool offline only with with a list of empty folders and without mapping the nmt drive?  As technically we always need folders in this kind of projects to show pics on nmt's, why not basing the scan on the folders name only.  We will have the opportunity to do all the job offline and then update the nmt's (and we will not taking care of the movie file name).
> I noticed that the source path files are moved to the %Systemdrive%\Prog~\Yadis\Workspace\000x folder (but without moving the movie file).
Why not updating the source path files directly?
« Last Edit: September 02, 2010, 12:04:13 pm by C00per » Logged
zaimben13
« Reply #6 on: September 02, 2010, 05:28:11 pm »
 Grin Grin Grin Grin i knew that this software will  help you guy! hope other people will use it .. the more people will use it on the med, the more chance we'll have to get an adaptation of yadis directly on med!
concerning the  suggestions:
actually yadis need to have all your film in each folder with only the reight name of the film (as it is said in the user guide of yadis!! so its normal that you only got some information if your film is not in the folder or if the folder is empty (i know, it would have been cool if it was like you said but this soft is always improoved by its creator "fred-l" so in a new version, may be he will implemant it!
i know that in the v2 that is coming soon (no precise date will be given...) new languages are on the line (synopsis directly create in the languages you choose: dutch, spanish, italian.... yadis will use a lot of new database!!!
you will aslo be able in this v2 to modify by your self the info concerning(manually) the codec used, the subtitle, the laguage of the film eetc... all manually if you want(at this moment yadis dont give you this opportunity!
a lot of new feature are also on the line may be  the one you are looking for .....
« Last Edit: January 07, 2011, 11:14:40 am by zaimben13 » Logged
ps3 slim 250go
Topshotta
« Reply #7 on: September 15, 2010, 05:39:21 pm »
I'm liking the way this looks, i should have my M8r in a few days and I can't wait to try this out.
« Last Edit: September 15, 2010, 09:39:55 pm by Topshotta » Logged
Topshotta
Mede8er DD+ with internal WD AV-GP 500GB Hard drive
LG 42" 720p LCD TV,
Motorola Netopia wireless G router using wired connection
WD My Book Studio 2TB External Hard drive over network
Logitech Harmony One remote control
zaimben13
« Reply #8 on: September 15, 2010, 07:36:45 pm »
welcome in the yadis communyty men!!! please note that there is an incomming v2  of yadis that will include possibilyti to create deutsh and nederland synopsis!!!!! i will warn the communyty when it will be released!
ps3 slim 250go
Korras
« Reply #9 on: September 16, 2010, 09:10:12 am »
to me, it doesn't even matter that the synopsis is in english. I actually prefer it that way. but this whole app is nice and simple. I like. Smiley
TimoLimo
« Reply #10 on: September 16, 2010, 09:32:17 am »
I have to say I don't really appreciate you spamming my message inbox, zaimben13..
It's like when you shop in a store and some pushy salesman comes over to bother you and talk you into buying something..
I always walk away in that scenario..
And that's exactly what I do here.. I won't try the application because you come on waaay too strong to get people to try it.. I'm probably a very paranoid person, but in this case YADIS "makes my spidey sense tingle": what is the hidden agenda with all this relentless pushing and promoting of this application? I can appreciate a developer trying to reach more people for his/her applciation, but the way it is handled on this forum is very... unprofessional (and kind of childish)..
Just my two cents..
And also, this is just my personal opinion, so don't let this comment influence your opinion of this great Mede8er forum or its users as I only speak for myself... Best of luck!
Mede8er model: Mede8er FW 4.0.5 (non-DD+)
Hard disk: WD Caviar Green 2TB, WD20EADS,
Network: CAT6 LAN 100Mbit/1Gbit, connected through D-Link DIR-655 router and D-Link DGS-1008D switch
PC: Windows 7 Home Premium 64-bit
NAS: Thecus N7700 (NFS+Samba)
Display device: 50" Pioneer KRP-500A, connected via HDMI
Audio: Yamaha RX-V2095 via COAX S/PDIF
TimoLimo
« Reply #11 on: September 16, 2010, 10:53:19 am »
It seems I will have to review my previous statement.. Wink
I didn't realize it's the same yaDIS that Fred-L created for the HDI Dune mediaplayers..  Lips sealed
So in that regard I retract my statement of not trusting or trying the yaDIS application, as I have tried it earlier this year when it was posted on MPCClub... It was pretty solid, but haven't tried it since..
But I do however stand by my previous statement regarding its promotion here..  Grin
Racker_CRO
« Reply #12 on: September 16, 2010, 12:52:22 pm »
Just my two cents..
I agree with you TimoLimo. I received 3 PMs regarding this software. As you said I can understand someone trying to promote it's software but it should be done in more sensitive way, not by bothering ppl with spam. So after I received 3 PMs I did try it and it's nice....but overall look is less eye-candy than the one from YAMJ so I will stick with YAMJ for now.
Once again this is my opinion only, and I do support anyone willing to make the best of this WONDERFULL player, so keep up the good work and little less propaganda :-).
Genius may have its limitations, but stupidity is not thus handicapped.
zaimben13
« Reply #13 on: September 16, 2010, 02:13:03 pm »
Just my two cents..
 HI guys ! ok first of all, i have to say SORRY for the fact i send you both more than 1 message  in your  message inbox, i m really sorry but i need to precise something:
actually i was  making some research on the forum on some topics, i saw that some of you guys experienced some problemes with using yamj or thumb gen or some other soft... so i decided to help you by sending you ONE mail  which contains the link to those tutorial!
if you received more than one message from me in your inbox, i  say sorry one more time, its my fault,  yesterday i sent more than 15 mp in one hour and it seemed that at a moment my onw message box  encontered some bugs,  the page didn't want to refresh during some minutes so i  was pushing like an idiot on "send" button  thinking it will send it .... in fact everytime i pushed it it send you the same mail so im sorryu again guy, i only wish to send yu only one MP not 3 as it was the case for you racker cro trust me! im sorry... but by the way, i  send some mp(to apologise...) to those  who may have received more than one mail from me i tought you were part from thos people, if its not the case  , i apologise agan in my post, i didnt want to spam you with 3 mp men!  i just send you 1 and my inbox bugged so ..... SORRY FOR ALL OF YOU WHO MMAY HAVE RECEIVED MORE THAN ONE MP FROM ME!!! it was a BUG!
anyway, nice to see that this soft from FRED-l  make you happy for most of you.....
even  playon hd users seems to like it in their official forum......lol!
ps3 slim 250go
zaimben13
« Reply #14 on: September 24, 2010, 12:08:56 pm »
hey guys!
here is a link to megaupload where you will find my own personnal synopsis created with yadis!!! there is  exactly 188  complete synop^sis that the med500 community can use with med500x !!!
just note that those synopsys has been created by myself and correspond especialy to my own file (mkv....) the info concerning the codec video, audio codec, languages (it is in french...) and subtitles.... are related to my own files and ma y not match your own mkv file ....
for those who do not understand french, you can just download the archivce (50 mo aproxymatly) and just see the quality of the word made by yadis....
http://www.megaupload.com/?d=C01NWYJF
plus here 225 more
http://www.megaupload.com/?d=PP66ZQ3N
« Last Edit: September 30, 2010, 08:04:50 pm by zaimben13 » Logged
ps3 slim 250go
Pages: [1] 2 3 ... 5   Go Up
