Author Topic: Philips 9400 Pronto Remote xcf file for Mede8er MED500X  (Read 15350 times)
Offline spydey
Re: Philips 9400 Pronto Remote xcf file for Mede8er MED500X
« Reply #15 on: July 04, 2011, 12:15:27 pm »
Sounds great,
I am finding that most of the remote control codes work for the MED500X2 remote, but a lot of codes have a different function.
One of the things which I did find was that the codes for left,right,up and down only move a single position on continuous hold. The original remote will scroll down the entries when holding down the button. I am still trying to find the correct code which also makes this possible on the Pronto.
Regards,
Spydey
Offline smi
« Reply #16 on: November 13, 2012, 03:17:37 pm »
Will these codes work for the 1000X3D too or could you provide an additional xcf file?
I plan to by a 1000X3D soon and have a Pronto 9600.
Hartmut
600X3D
HDMI in Yamaha RX-A 3020
HDMI in Beamer Epson TW 4400
wired network to Qnap TS 110
wired network to Qnap TS 212
« Reply #17 on: November 13, 2012, 03:47:58 pm »
smi
Pronto codes for X2 / X3 (codes are the same)
http://www.mede8erforum.com/index.php/topic,7224.msg46046.html#msg46046
