Author Topic: Problem with .MKV (x264) file reproduction - M8 just skips it  (Read 1213 times)
zdravo
« on: July 19, 2010, 05:26:32 pm »
I downloaded this movie:
Bullitt (1968) DVDRip x264-DEViSE
It's in .MKV format and it has two parts (CD1 and CD2, 2 x 700MB).
I already played it on PC on BS Player, VLC and with WMP.
And it woked OK.
I sent them to Mede8er by network and first part wont to start, just skips it and goes on second CD.
This is file info:
"Bullitt.1968.DVDRip.x264-DEViSE
Release Date ........: 03/05/08      Language ......: English
Theather Date .......: 00/00/00      Subtitles .....: n/a
Store Date ..........: 00/00/00          Archives ......: 98 x 15 mb
Video Codec .........: x264              Framerate .....: 23.976
Video Bitrate .......: 1820 Kbps     Runtime .......: 01:53:43
Resolution ..........: 688x384         Country .......: USA
Aspect Ratio ........: 16:9                Genre .........: Crime
Audio Codec .........: AC3               Rating ........: 7.5/10
Audio Bitrate .......: 192 kbps        Source ........: DVD Retail "
Any suggestions?
Mede8er FW v4 - 25 January 2011  with  Seagate 1,5TB connected by LAN to PC by HDMI to TV
+ Panasonic 32" TX-L32S10E Full HD LCD TV
Win 7 64bit on Q9550 8GB RAM
+ Linksys WRT54GL FW DDWRT v24 sp1 10020
MarioB
« Reply #1 on: July 19, 2010, 05:49:04 pm »
Could you put MediaInfo about this 2 video files... Maybe the file become corrupted during transfer to the Mede8er???
Could you try to play this file on PC from Mede8er (over network).
Cheers
the-osiris
B8a Tester - 1000X3D
« Reply #2 on: July 19, 2010, 05:56:31 pm »
Try to copy via USB, might have corrupted while copying over network ...
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
tachita
Guest
« Reply #3 on: July 19, 2010, 06:13:43 pm »
like MarioB say , post the MediaInfo log .
cd1 part or chapter, or whatever is,  could be corupted.
did you try to use Go To button for choosing the right chapter?
zdravo
« Reply #4 on: July 19, 2010, 09:24:47 pm »
Cheers
Well, that's good idea, will try  it in 2-3 days, when I get home.
Now I am not home.
Also I will try to copy it by USB
Only thing I saw already is that M8 calculate it's size and length in H:M:S but no preview and no play.
Thank you all for fast replies and helping me, I am pretty sure that I will solve the problem when I ge home.
Regards
When I
zdravo
« Reply #5 on: July 21, 2010, 11:44:19 pm »
So, I am home now and I treid this:
1. I started both movie files from my PC over network on Mede8er.
    Both were working OK.
2. I send the first (problematic) file to USB stick and I transferred it to Mede8er and it wasn't working.
Here is MediaInfo:
CD1:
Complete name                    : \\Mede8er\hdd1\Filmovi\Strani\Bullitt (1968) DVDRip x264-DEViSE\Bullitt (1968) DVDRip x264-DEViSE CD1.mkv
Format                           : Matroska
File size                        : 700 MiB
Duration                         : 1h 0mn
Overall bit rate                 : 1 616 Kbps
Writing application              : AVI-Mux GUI 1.17.7, Aug  8 2006  20:59:17
Writing library                  : matroska muxer by Alexander Noe, build date Aug  8 2006
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : Main@L5.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 2 frames
Codec ID                         : H264
Duration                         : 1h 0mn
Bit rate                         : 1 392 Kbps
Nominal bit rate                 : 1 517 Kbps
Width                            : 688 pixels
Height                           : 384 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.220
Stream size                      : 603 MiB (86%)
Writing library                  : x264 core 47 svn-532
Encoding settings                : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x131 / me=hex / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / chroma_qp_offset=0 / slices=1 / nr=0 / decimate=1 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=2 / wpredb=1 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1517 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language                         : English
Format                           : AC-3
Format/Info                      : Audio Coding 3
Format profile                   : Dolby Digital
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1h 0mn
Bit rate mode                    : Constant
Bit rate                         : 192 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Stream size                      : 83.2 MiB (12%)
Language                         : English
CD2:
Complete name                    : \\Mede8er\hdd1\Filmovi\Strani\Bullitt (1968) DVDRip x264-DEViSE\Bullitt (1968) DVDRip x264-DEViSE CD2.mkv
Format                           : Matroska
File size                        : 693 MiB
Duration                         : 53mn 10s
Overall bit rate                 : 1 821 Kbps
Format                           : AVC
Codec ID                         : H264
Duration                         : 53mn 10s
Bit rate                         : 1 593 Kbps
Width                            : 688 pixels
Height                           : 384 pixels
Color space                      : YUV
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 0.251
Stream size                      : 606 MiB (87%)
Language                         : English
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 53mn 10s
Bit rate                         : 192 Kbps
Bit depth                        : 16 bits
Video delay                      : 101ms
Stream size                      : 73.0 MiB (11%)
Language                         : English
tachita
Guest
« Reply #6 on: July 21, 2010, 11:47:09 pm »
from me i recomend you to remux them ,
use MKVMERGE for that........
zdravo
« Reply #7 on: July 22, 2010, 02:40:44 pm »
Tachita thank you very much, I used the program you mentioned and all is OK now.
I just remuxed first part of the movie, because it was making problems.
File size has decreased by 300-400 kb and plays perfectly.
Thank you once again Wink
