Author Topic: Wifi Transfer speed  (Read 2102 times)
daniescholtz
« on: November 25, 2009, 01:32:23 pm »
Anybody tested the new dongle yet and can tell me how long it takes to copy a 700MB file? Wanna calculate what is the max transfer rate.
Mede8er: MED5XX FW 2.0.2
Hard Drive:  Seagate 1TB
Network: TPlink switch 10/100mbit
TV: Samsung 32" Full HD connected via HDMI.
Computer: Windows XP 32bit PC. Connected to Mede8er NAS share or USB Slave.
Monkeyface66
« Reply #1 on: November 26, 2009, 05:04:11 am »
Some WLAN transfer speeds from a competitor (Xtreamer) for comparison:
Info: PC and Xtreamer are both connected to the router via WLAN; signal strength is stable and good.
Uploading to the media palyer's internal HDD: 1,20 MBytes/s
Downloading  from the media player's internal HDD to PC: 1,00 MBytes/s
Via WLAN g + using Windows Explorer to connect to the media player.
Administr8or
« Reply #2 on: November 26, 2009, 06:22:44 am »
With V1.2.2a WiFI transfer speed via Samba
Upload to Mede8er - +-1MB/sec
Download from Mede8er - +-2 MB/sec
greywall
B8a Tester - X2
« Reply #3 on: November 26, 2009, 12:35:28 pm »
Upload to Mede8er : min 1,8 MB/sec-->max 2,59 MB/sec
Download from Mede8er:  2MB/sec
My configuration
PC Windows XPpro SP3 --> Wireless N Gigabit Router Netgear WNR3500--> Mede8er with Xtreamer wifi antenna.  Grin
Administr8or
« Reply #4 on: November 26, 2009, 12:43:35 pm »
Hi greywall
Nice!  Yr results better than mine as you are using n router. I used Super G router 108mbs.
Ormbett
Senior Member
« Reply #5 on: November 26, 2009, 04:44:39 pm »
Any difference when using unencrypted versus WPA?
Kind regards
Ormbett
•250ml water (cold or soda water)
•200g flour (325 ml)
•400 ml heavy/whipping cream
•butter
Serve with cloudberries and whipped cream!
greywall
B8a Tester - X2
« Reply #6 on: November 26, 2009, 05:26:37 pm »
I have had these results with protection wpa2-PSK [aes], but I imagine that the benefits will best without protection.
During the weekend I will test Wink
Ormbett
Senior Member
« Reply #7 on: November 26, 2009, 07:24:24 pm »
Thanks greywall!
Kind regards
Ormbett
•butter
« Reply #8 on: December 03, 2009, 11:29:28 pm »
Hi guys,
I just got my Wifi mede8er dongle yesterday.
Did some tests after setup over Samba with Netmeter.
Upload to Mede8er - +-1.2 MB/sec
Checked my Linksys WRT160NL and saw that is was not running on Wireless-N but Wireless-G mode.
Tried to play with some wireless settings to force it to connect to Wireless-N, but didn't succeed in that.
Any of you maybe some tips on router settings to force the wireless-n speed?
distance between router and mede8er wifi dongle is about 5 meters, signal quality is very good, so that cannot be the cause that my router is stepping down to wireless-g mode.
Edit:
Now with firmware 2.0.1 and a new Netgear router got it better:
http://www.mede8erforum.com/index.php?topic=704.msg4130#msg4130
Noticed that switching from WPA to WPA2 give some improvement over Samba (don't use NFS so couldn't test that).
Going from WPA to WPA2 with my new Netgear router improved from 2.5-2.8 MB/s average to 3.2 MB/s copy from PC to Mede8er. (with Teracopy).
« Last Edit: December 29, 2009, 08:20:43 pm by Maasbommel » Logged
