Pages: [1] 2 3 ... 5   Go Down
Author Topic: FTP and NFS  (Read 6327 times)
PeeBee
« on: November 08, 2009, 05:45:39 pm »
Hello Mede8er users,
I'm a new Dutch user of the Mede8er since yesterday (before I used the Egreat NMT M31B)
I like this new mediaplayer so far, but missing the use of FTP, Filezilla and is not possible right now.
Hopefully this will be made possible in a new firmware version.
Now I read alle the articles about NFS, but still don't work in my configuration for streaming with my NAS
Router: Linksys 610N
NAS: Synology 107+ (NFS enabled)
Still get message in Mede8er that's not working for  IP 192.168.1.104:/e for the whole drive or 192.168.1.104:/video for my sharename.
Firmware 1.2.2 and fixed IP
Someone knows what I'm doing wrong ?  Huh
I'm using Win7-64 and read the applicable articles on the forum and performed the registry adjustments without results
« Last Edit: November 08, 2009, 06:07:58 pm by PeeBee » Logged
Administr8or
« Reply #1 on: November 08, 2009, 07:19:43 pm »
Hello PeeBee
Welcome to the Mede8er forum
FTP functionality will be in next firmware release and this will be very soon --hoping for this week
Re NFS I cannot really help you on the Synology 107+ as I dont have one but the basic rules remain the same for NFS to work
1) The NFS server must have have a IP (you have this) and a export name (share) but how you set up the export (share name ) on the Synology I really dont know.
2) The Mede8er as the "client" needs to know the IP of the server and the export (share) name and you have showed examples
IP 192.168.1.104:/e for the whole drive or 192.168.1.104:/video for my sharename.  --  I would remove the colon so that it looks like this and try again   IP 192.168.1.104/e         192.168.1.104/video
Sorry I cannot be of more help
PeeBee
« Reply #2 on: November 08, 2009, 07:36:14 pm »
Thanks for your quick response.
I will try tonight your suggestions
PeeBee
« Reply #3 on: November 08, 2009, 11:18:22 pm »
Well, I managed to use NFS now, shame on me  Grin
In the Synology NAS I had to specify the user rights for NFS per share
so for mede8er correct sharename is: 192.168.1.104:/volume1/video
Administr8or
« Reply #4 on: November 08, 2009, 11:23:54 pm »
Hello PeeBee
Great that you got it working - Maybe you could post some information on how to set the user rights for NFS on the Synology 107+to help others.
PeeBee
« Reply #5 on: November 09, 2009, 12:18:09 pm »
Good idea, this evening I will clarify and also with some tips
charl
« Reply #6 on: November 15, 2009, 07:19:57 am »
How do i know what my share name is? Is it the name i assigned to my computer when i set up the network sharing or the name of my home network?
Administr8or
« Reply #7 on: November 15, 2009, 07:30:01 am »
Hi charl
Are you trying to use NFS ??
charl
« Reply #8 on: November 15, 2009, 08:24:59 am »
Morning,
Yes i am but must admit i don't know much about it. I'm also battling with NAS. I have activated NAS and i have set up itunes media player location to be //mede8er/c but when i import a cd nothing gets sent to hard drive, not sure if the issues are related and if i have everything set up correctly. I don't normally battle with these kinda technical stuff but i'm stumped here.
charl
« Reply #9 on: November 15, 2009, 08:33:10 am »
Also when looking at "My Network Places" on my PC i can't see the hard drive of the mede8er, must it say HDD as in the manual?
Insomniac
Moder8or
« Reply #10 on: November 15, 2009, 10:13:22 am »
To find your Mede8er MED500X on your network:
1. Ensure NAS server is running on your Mede8er (SYSTEM SETUP > NETWORK > NAS > ON)
2. Go to [START] > [RUN]
3. Type in: \\mede8er\
4. Press [ENTER]
OR
2. Launch Windows Explorer (Hold in the [WINDOWS] button and press 'E')
3. Type the following into your address bar: \\mede8er\
OR
1. Ensure NAS server is running on Mede8er
3. Go to My Network Places > Entire Network > Microsoft Windows Network > Workgroup > Samba 3.0.23c (Mede8er)
Insomniac
Moder8or
« Reply #11 on: November 15, 2009, 10:14:51 am »
If you want to go directly into the Hard Drive then type in: \\mede8er\HDD
charl
« Reply #12 on: November 15, 2009, 10:29:45 am »
4. Press [ENTER]
OR
OR
Confirmed that media player is on my network thanks.
charl
« Reply #13 on: November 15, 2009, 10:37:14 am »
I get "C" instead of "HDD", i'm guessing it's the same. If i copy files to this location \\mede8er\C, i can access these files via the NET and Hard drive of the players menu. On NET is comes up under WORK GROUP. Does it show up on both because of the network share? Sorry if this sounds like a dumb question but i'm just trying to understand the workings of it.
I just need to figure out now how i can download directly to the hard drive when importing cd onto iTunes without getting error messages.
Insomniac
Moder8or
« Reply #14 on: November 15, 2009, 10:41:59 am »
My apologies - you are correct.
I am busy beta testing 1.2.3 where the label appears to have changed, hence my confusion - 1.2.2 uses \\mede8er\c for HDD
Your best bet would probabgly be to 'map' the drive - then you are assured of an easy drive path.
Pages: [1] 2 3 ... 5   Go Up
