Punta
Offline
« Reply #15 on: June 04, 2010, 10:10:44 am » |
Hi there,
I also have a problem with WMV files, V2 played them fine but V3 does not, it says "Unsupported Video" on some and "no audio" on others. I haven't tried V3.2 which I will try later today but if you know why this is please let me know!
Regards Punta
Riffer
Offline
« Reply #16 on: June 04, 2010, 10:24:21 am » |
Is there a timeline to have the sdk failures fixed? With this bunch of errors I will not upgrade, the new features and fixes are not really the golden goal...
Product & firmware version: Mede8er MED500X f/w v2.0.2 Audio setting: SPDIF Passthrough / Night mode OFF Video: Samsung LE32B650 Video setting: PAL, 24Hz ON, 16:9 Media Source: Windows XP SP3 SMB and/or FTP > Wired Network Hard Drive: Samsung F3 HD203WI, formatted using Mede8er old Firmware, then upgrade to 2.0.2
snoegeleur
Offline
« Reply #17 on: June 04, 2010, 11:02:29 am » |
Any idea when this green line in top of the screen will be fixed caused bij sdpif handshake?
« Reply #18 on: June 04, 2010, 12:35:07 pm » |
Hi there,
Regards Punta
See releae notes of 3.0.2. I can confirm that I saw same on V3 and now is fixed.
djelloun
Offline
« Reply #19 on: June 04, 2010, 12:39:54 pm » |
Brilliant Update, speed is remarkably faster !!! Go on Med Team
Perry
Offline
« Reply #20 on: June 04, 2010, 01:29:11 pm » |
In media library "Hard drive" in russian must be "Жесткий диск".
« Last Edit: June 04, 2010, 01:34:25 pm by Perry »
MarioB
Offline
« Reply #21 on: June 04, 2010, 01:47:06 pm » |
I have question regarding "Restore configuration" option. For example, now I have installed on my Mede8er FW 3.0. Can I save configuration, use emergency procedure to install FW 3.0.2 and then after reset (unplug power) use this saved configuration. It should work between FW 3.x.x. versions, right?
Mede8er model: Mede8er_MED500X_V4.0.4_MOD_BY_SHIZZL_INC_HDaudio Hard disk: WD 1TB, WD10EARS, SATA II, 64MB Cache, WD Caviar Green Network: CAT5 LAN 100 Mbit, connected through D-Link 100Mbps switch to the SpeedTouch 780 router PC: Win7 SP1 (64bit, Home Premium) on HP4720s with haneWIN NFS server Display device: 40" Sony Bravia KDL-40W4000, connected via HDMI Audio: TV only, HDMI pass through
Ormbett
Senior Member
Offline
« Reply #22 on: June 04, 2010, 02:46:14 pm » |
It should have worked from v2x to 3x too, but it did not. So I suggest you to not using the restore function because there are no guarantees it will work even if it should  Kind regards Ormbett
•250ml water (cold or soda water) •200g flour (325 ml) •400 ml heavy/whipping cream •butter Serve with cloudberries and whipped cream!
« Reply #23 on: June 04, 2010, 03:07:57 pm » |
Used this several times, without problems between V3 to 3.0.2 Just give it a try, you can always do a reset to default or reload FW again. But I am convinced it works starting from V3 to upper version 3.0.2
uka
Offline
« Reply #24 on: June 04, 2010, 04:02:08 pm » |
Video Stream#1
Video Codec: wmv3x Video Bitrate: 1008K Video Size: 520x416 Aspect Ratio: 1.2:1 Frame Rate: 25.00fps Audio Stream#1
Audio Codec: wma9 Audio Bitrate: 15K Track: 1 Sample Rate: 16000
wmv files not open with Mede8er
Skizmo
Offline
« Reply #25 on: June 04, 2010, 06:34:56 pm » |
Thanx for wiping my webradio favorites
djtzar
Offline
« Reply #26 on: June 04, 2010, 06:54:33 pm » |
how long should the upgrade process take ? been at the mede8er logo for almost 10 minutes and don't want to turn it off for fear of damaging the hardware.
sneferu
Offline
« Reply #27 on: June 05, 2010, 05:27:37 am » |
I must be be very lucky  I have applied 3 firmware upgrades 2.0 -> 2.1.0, 2.1.0 -> 3.0, 3.0 -> 3.02 I have followed the instructions (i even re-read them just prior to starting). Each upgrade has been successful. Why is it others have problems with theupgrade? I know is a little harder then 'clicking' an update in menu - but it is straight forward. To reduce the forum response burden on Insomniac, Maasbommel and others, perhaps we should all take a breath and re-read the instructions maybe even twice! Regards Lucky with firmware upgrades - Sneferu
Delirius
Offline
« Reply #28 on: June 05, 2010, 10:04:47 am » |
Sneferu, though the instructions are extensive and reading will solve most of the problems stated by different users, there are some "strange" sentences in this instruction. I just updates my Mede8er for the first time and I was waiting for my mede8er to reboot and led-light to turn green or red (as stated in instruction) but that never happened. The updated was successful anyway. Apart from that is stated that you must press the power butto for about 10 seconds. It took me four times to realize this applied for the power button on the device itself and not the one on the remote control (ok, my bad  ). So, maybe it is a little harsh to blame the users. The update-instructions were a little blurry as well.
fonggekhuat
Offline
« Reply #29 on: June 05, 2010, 11:10:08 am » |
I cannot play file like .flv after updated to v3.0.2 what should I do. Thanks!
