Pages: [1] 2 3 ... 6   Go Down
Author Topic: Feedback: MED500X v3.0.2 -- 3 June 2010  (Read 9689 times)
RothaNL
« on: June 03, 2010, 07:19:28 pm »
Yesss, thank you!
Wmvhd files working correctly now. No more audio problems. Grin
Thans again! Smiley
« Last Edit: June 14, 2010, 07:04:31 pm by Insomniac » Logged
Mark1981
« Reply #1 on: June 03, 2010, 07:31:48 pm »
Installed and can see and HEAR my series again.
Thanks for the quick response and fixes.
Keep up the good work guys
Mede8er model: MED500X
Board: 1073DD
Bootloader: 0000.0202.1026
Firmware: V4.04 No HD Audio
Internal HDD: none
External USB HDD: Iomega 500 Gb
Display: Samsung LE37CE530
Audio connection: HDMI to TV
greywall
B8a Tester - X2
« Reply #2 on: June 03, 2010, 08:05:20 pm »
Thank you for having corrected the translation in Italian.
Great support for a very good product.  Wink
Regards
greywall
Ormbett
Senior Member
« Reply #3 on: June 03, 2010, 09:00:51 pm »
Nice work, downloading!  Smiley
Kind regards
Ormbett
•250ml water (cold or soda water)
•200g flour (325 ml)
•400 ml heavy/whipping cream
•butter
Serve with cloudberries and whipped cream!
bluntspoon
B8a Tester - X2
...no one really knows...
« Reply #4 on: June 03, 2010, 09:18:28 pm »
I like  Grin
Fixed: Select Movies Tab, the Folder Play function plays previously played video and not the video within the folder selected
Home Theater Setup:
Samsung LA40C650L1R
Mede8er MED500X2
Mede8er MED400X
mobetterblues
Online Online
« Reply #5 on: June 03, 2010, 09:29:34 pm »
DVD resume on VIDEO_TS structure - Not working -- SDK
On certain 16:9 DVD menus - selection highlight is misplaced -- SDK issue
The menu issue is small and just irritating
The Resume on TS folders is a right pain and needs to be sorted very quickly if possible
With lots of children in my house this is going to drive them nuts
PhV
« Reply #6 on: June 03, 2010, 10:51:51 pm »
Big up for this very quick fix of V3.0 bugs !!!
MED500X Fw 2.0.2 with HD WD Caviar 1To (5400RPM)
Mede8er networked (RJ45) direct to FreeBox (router & ADSL modem)
Home network (wifi): 4 PCs (XP, Vista 32bits, Seven 32bits/64bits) - Archos  5IT - Palm T|X
Plasma 32" Panasonic 32PZ81 -Audio thru HDMI to TV (decode to 2ch)
Cooper
« Reply #7 on: June 04, 2010, 12:35:12 am »
I have got a big problem since I installed V3.02. After installation and reboot the mede8er stops working after approximately ten seconds andi have to reboot again but then stops working again after ten seconds ..Help!!
« Reply #8 on: June 04, 2010, 12:45:44 am »
What firmware had you installed before going to 3.0.2?
Cooper
« Reply #9 on: June 04, 2010, 01:29:59 am »
V 2.1.0. was installed when I bought the mede8er.  By the way the blue indicator stops and so also the mede8er itself stops after after scrolling through the menu's between 10  and 20 seconds after reboot). I tried the V3.0 but had the same problem. Now i rolled back to V2.1.0 and all problems are solved.
I installed V3.0.2 again. I still have the same problems. But it seems that blue indicator goes off and the tv display disappears but the mede8er is still "running"but is not reacting onthe on/off button as well as of the remote control or the mede8er. The only thing to do is to reboot (unplug dc jack). But then the problem occurs.
Note: 1 Terabyte samsung hardisk installed.
« Last Edit: June 04, 2010, 01:55:49 am by Cooper » Logged
tachita
Guest
« Reply #10 on: June 04, 2010, 02:33:53 am »
Try to redownload the fw now when Ftp connection is free.
Also try different usb stick, if dont have try to full format the curent one.
After upgrade when M8R ask for make setup just unplug M8R.  Do those later , after reboot.
Insomniac
Moder8or
« Reply #11 on: June 04, 2010, 03:50:48 am »
Have you tried the TVSYS button as per the PDF included in the firmware download?
I suspect that your TV output has changed to default.
Try using composite RCAs for troubleshooting and manually set for your TV output resolution.
You haven't provided any of your TV output connectivity.
winston
« Reply #12 on: June 04, 2010, 07:25:03 am »
Thanx for updated.
I can't play WMV files with this details :  it say   Unsupported Video
Frame width                 640
Frame height               360
Data rate                       1297kpbs
Total bitrate                   1425kpbs
Frame rate                    30frames/second
What's wrong with this file ? please any advice ...
« Last Edit: June 04, 2010, 07:36:28 am by winston » Logged
c0de1
« Reply #13 on: June 04, 2010, 08:04:00 am »
Love ths product very much !! thanks
When can we aspect the new GUI and a fix for the resume on TS_VIDEO/ISO ?
Product & firmware version: Mede8er MED500X f/w v4.0.4 3 march 2011
Audio setting: pcm / Night mode OFF
Video: HDMI output > Samsung 37" LCD LE37B651
Video setting: 1080p 60Hz,24Hz ON,16:9
Media Source: Wired Network > Windows 7 SMB shares
Hard Drive: Seagate 500 Gig, formatted using Mede8er setup
« Reply #14 on: June 04, 2010, 09:10:28 am »
Thanx for updated.
Frame width                 640
Frame height               360
Data rate                       1297kpbs
Hi Winston,
Could be anything.
If you want to make some proper feedback more detail is needed. Please make a separate post in the technical support issues section and look at the Technical Support Guidelines for supplying enought details to make this possible. At least some output made with Media Info is needed...
Could be containing unsupported coded,
Pages: [1] 2 3 ... 6   Go Up
