That is odd behaviour indeed - thank you for raising it.The Ken Burns is really more of a slideshow special effect and one wouldn't really be zooming in or out.just play and let it roll...To manage and zoom I feel you should really be turning Ken Burns off
Agreed. I only noticed it because the Ken Burns effect was on by default after I upgraded the firmware. I have turned it off but, if zoom can work, then it would make sense to enable both buttons. Even in a slide show someone might want to zoom in on some detail in a particular picture.
Found an issue with internet radio. On V1.2.2a it work fine and did all updates, after installation of V2.0 it did not work anymore and comes back with download failed. What can be done to solve this issue?
