Author Topic: mpg does not play  (Read 804 times)
arjan64
« on: June 04, 2010, 09:08:45 pm »
Hi!
I have an .mpg-file of about 1 GB that refuses to play. Even with FW 3.0. The info I extracted is given below. Is this a codec problem? If so, how can I cut off a small piece to upload to the service-centre? Alternatively: the file extension is .mpg, but the analysis suggests that it is a WMV-file. Should I rename the file? Other suggestions?
Arjan
General
Complete name                    : I:\muziek-video\Camel\Camel - Live At The Billboard Live Club Hollywood 97.mpg
Format                           : Windows Media
File size                        : 1.19 GiB
Duration                         : 1h 53mn
Overall bit rate mode            : Constant
Overall bit rate                 : 1 498 Kbps
Maximum Overall bit rate         : 1 511 Kbps
Movie name                       : CAMEL coming on age
Performer                        : MONTY
Encoded date                     : UTC 2004-08-21 16:59:41.736
Copyright                        : 21/08/2004
Video
Format                           : WMV1
Codec ID                         : WMV1
Codec ID/Info                    : Windows Media Video 7
Duration                         : 1h 53mn
Bit rate mode                    : Constant
Bit rate                         : 1 368 Kbps
Width                            : 640 pixels
Height                           : 480 pixels
Display aspect ratio             : 4:3
Frame rate                       : 25.000 fps
Nominal frame rate               : 24.000 fps
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 0.178
Stream size                      : 1.09 GiB (91%)
Language                         : Spanish
Audio
Format                           : WMA
Format version                   : Version 2
Codec ID                         : 161
Codec ID/Info                    : Windows Media Audio
Duration                         : 1h 53mn
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 44.1 KHz
Bit depth                        : 16 bits
Stream size                      : 104 MiB (9%)
Language                         : Spanish
« Reply #1 on: June 04, 2010, 09:16:30 pm »
Have you tried to upgrade to latest version 3.0.2?
arjan64
« Reply #2 on: June 04, 2010, 09:38:16 pm »
I'm busy installing it. I'll be right back!
A.
arjan64
« Reply #3 on: June 04, 2010, 09:51:21 pm »
... no difference with 3.0.2!
Does the info I gave hint into any direction?
A.
tachita
Guest
« Reply #4 on: June 04, 2010, 09:52:05 pm »
I think it will not play.
It iS very possible that you'll see M8R freezing.
But you'll have to try.
« Reply #5 on: June 04, 2010, 09:57:22 pm »
Just checked my collection and compared to specs:
http://www.mede8er.com/index.php?option=com_content&view=article&id=22&Itemid=60
I think it is because Windows Media Video 7  codec, I have Windows Media Video 9 codec files that play well.
arjan64
« Reply #6 on: June 05, 2010, 12:42:38 am »
So how strange is it to want to play an old file?
Should I file a feature request on the appropriate sub-forum?
The concert in the .mpg-file is pretty good, and it would complete
my set of concerts in 1971 and in 1984 with a third concert in 1997! ;-)))
A.
tachita
Guest
« Reply #7 on: June 05, 2010, 12:52:32 am »
First try to change extension to wmv, but i doubt that will work.
If not use Handbrake software to convert him to mkv.
arjan64
« Reply #8 on: June 05, 2010, 01:02:01 am »
I'll follow your suggestions. Still I feel like surrendering when I have to convert my files! My pc has no problem, and I am not a computer-whizz-kid, so how difficult can it be? I bought a media-player and have a medium that I want to play. Rock it, Mede8er! Get a matching codec!
A.
ps. Don't understand me wrong: I really like this little black box! Just making an attempt to optimize!
tachita
Guest
« Reply #9 on: June 05, 2010, 01:17:59 am »
That file isn't so big , if you have another download source it will be good.
Avoid wmv 1 and 2, these are not supported.
Harry_993
« Reply #10 on: June 05, 2010, 10:49:14 am »
sad but appearantly true.... Sad
Mede8er  MED500X 1073DD
Firmware: V3.0.5
Bootloader: 0000 0202 0016
« Reply #11 on: June 05, 2010, 01:35:08 pm »
The box is not a PC! It dosn't use software codecs. If you want to compare it to a PC it's like having a very powerful Video supporting 2D graphics card ( A matrox perhaps), and a very slowwwwww processor.  As long as the graphics card has hardware support for the codec then this arrangment  works.
