Author Topic: Virtual Linux as NFS server  (Read 6712 times)
« on: October 27, 2019, 04:25:17 PM »
Oracle VirtualBox Guides.
http://www.mede8er.click/Guides/NFSGuide.html
This guide uses a fixed VHD which Windows can mount to be loaded with media.
http://www.mede8er.click/Guides/NFSPro.html
This guide uses Windows Pro Tools for NFS clients to fill the ext4 drive via network access.
« Last Edit: December 09, 2019, 11:08:29 AM by jer1956 »
Re: Virtual Linux as NFS server
« Reply #1 on: November 14, 2019, 09:33:10 AM »
Hyper-V guide.
http://www.mede8er.click/Guides/HyperV.html
Copy files by making NFS drive Online or Offline. No virtual drive is used.
Upgraded to build a Generation 2 Virtual Machine, by disabling Secure Boot in its emulated motherboard firmware (not the actual motherboard bios).
« Last Edit: November 15, 2019, 12:49:13 PM by jer1956 »
« Reply #2 on: November 17, 2019, 10:34:20 AM »
Hyper-V guide being updated to use VHDX for the media store. That is natively supported by Windows and can be mounted to place media on it.  Hyper-V prefers using virtual drives.
« Reply #3 on: November 18, 2019, 08:21:02 AM »
Debian has some kind of memory leak.  If i use Dynamic Memory it always ends up using all  the memory allowed.
I am testing Ubuntu-Mate, which is also pihole compatible.
 https://ubuntu-mate.org/download/
The trick to changing its system files like fstab and exports is the command "sudo caja".  That opens the file manager with Root priviledges.
« Reply #4 on: December 09, 2019, 11:11:28 AM »
The original VirtualBox guide  has been changed to use a VHD for media storage.  Despite what Microsoft says, its possible to create a VHD bigger than 2TB.  That means we can use a format  that both VirtualBox and Windows supports, making it easier to load media.
