Author Topic: Unable to update firmware  (Read 7025 times)
Offline Graham N
« on: August 18, 2019, 12:02:37 PM »
all of my recently added films are giving me pixellated covers and pictures. It was recommended to me to upgrade the firmware from 3.02.
All I get when I hold the power button down is the logo with the number 8 in a circle with large blue and white blocks. No countdown, no flashing light on the USB stick, it just stays there static.
When I  put the firmware on the stick do I unzip it first or will the Mede8er do it. And does it matter which USB port I plug it into. I have unzipped it first and tried both ports with the same result.
I have theMED1000X3D
EDIT Just powered down the Mede8er and tried powering up again holding button for over 10 seconds. Still the same.
EDIT 2 Solved by further searching. Had to download a program to enable me to format the USB as FAT32
thank you
Graham
« Last Edit: August 18, 2019, 01:02:10 PM by Graham N »
