Author Topic: Cannot delete corrupted folders on HDD  (Read 14319 times)
Offline Veter
« on: July 18, 2019, 07:52:04 PM »
Hello,
I have several folders on the HDD connected to MED600X3D that got "corrupted" after usage a scraper.
They contain several jpg files with 0 size which cannot be deleted.
Folders themselves can be renamed, but cannot be deleted as well.
Would be very grateful for some advice/workaround.
Re: Cannot delete corrupted folders on HDD
« Reply #1 on: July 19, 2019, 02:55:50 PM »
You must connect to a PC and run Tools, under Properties.
Once fixed used the USB Removal tool linked in many places. Windows often corrupts the drive using  its inbuilt Safe Removal.
Offline Veter
« Reply #2 on: July 19, 2019, 06:50:05 PM »
Thank you for your response, jer1956.
Currently from my PC I can access MED600X3D as a network device and HDD connected to it, but I cannot delete folder from there as well.
Do you mean that I need to disconnect HDD from MED and connect directly to PC?
OK, I can try this. However what do you mean "run Tools, under Properties"?
Properties of a folder in Windows Explorer do not contain 'Tools' tab.
Could you please clarify?
Thank you.
« Reply #3 on: July 20, 2019, 08:14:51 AM »
It is not a Network Device tab. You only get the Tools Tab when directly connect via USB.
Offline Veter
« Reply #4 on: August 10, 2019, 10:51:40 AM »
Hi Jer,
do you mean Properties\Tools\Error-checking?
And one more question please: you mentioned the USB Removal tool. Must I use it for sure, or it would be safe enough if I shutdown my PC (without usage the Removal tool) and disconnect HDD when the computer is switched off?
Thank you.
Offline dotternetta
« Reply #5 on: January 07, 2020, 07:41:06 PM »
No no no! Do a check with the hdd in the mede8er, it has an file system repair function!! See manual
Offline Gasdatid
« Reply #6 on: April 03, 2020, 10:51:39 AM »
The story makes me very confused. You make it clear
