Author Topic: Fail firmware update  (Read 4992 times)
Offline jimbonta
« on: December 26, 2018, 06:22:07 AM »
hi, i tried to install the 6April2016 patch 2 firmware to solve the issues with 4.0.2 and i am stuck in this
first of all i turned the usb stick to fat32 and i did the procedure twice when i stuck the first time on this screen i turned off by the button the med and i start again unplug the power cord etc
what can i do now??
please help
Re: Fail firmware update
« Reply #1 on: December 26, 2018, 09:32:44 AM »
As another user found out....the old advice still stands. Find the oldest, smallest and slowest stick you have. A 4 or 8 Gb one lurking at the back of a drawer.
Offline jimbonta
« Reply #2 on: December 26, 2018, 11:43:05 AM »
exactly my modern 128gb usb stick couldn't be fat32 so i use an old usb stick which can be fat32 and it worked...
thank you!
