Pages: 1 ... 20 21 [22]   Go Down
Author Topic: ThumbGen  (Read 57595 times)
tachita_
Senior Member
« Reply #315 on: March 15, 2012, 10:12:19 pm »
Cannot see a reason why not.....
..and i dont know why ?
eentje
there aint noboby like eent :)
« Reply #316 on: April 12, 2012, 10:36:54 am »
question about thumbgen Smiley
is there a way to creat a movie collection like
folder
--Matrix
   -- matrix 1
  -- matrix 2
 -- matrix 3
and so that it wil show in videowall as matrix and when i click on it i can browse trough the movies in the collection ?
Greetz Smiley
-- med500x2 --synology ds1512+ 3x3tb -o onkyo reciever
saskir
B8a Tester - X2
Senior Member
« Reply #317 on: April 23, 2012, 10:53:24 pm »
Isn't this implemented in the new 2.0.6 Firmware? Series support is the keyword
Whooper
« Reply #318 on: April 26, 2012, 08:46:39 pm »
Not read all the pages back, but I will explain here some doubts:
use the profiles for the series and movies Mede8er
1 - How to read the plot of the movie / series in its entirety?
  There are plots that do not appear in the whole getting some stitches ... I refer to the plot that is generated in the XML file. No, and the plot in about.JPG.
2 - When you generate the films he creates beyond the about.JPG and folder.jpg and cover.jpg, it creates 3​​'s fanart (fanart1.jpg - fanart.jpg - fanart3.jpg) Usually I delete these 3 fanarts. Why it creates more three's fanart?
3 - how is tgmd file? practical example: "2.Coelhos.2012.1080p.BluRay.x264.DTS-HDChina.mkv.tgmd"
Generally also delete this file. What is?
4 - Why does Thumgen only identifies when subtitles are within the container (MKV). When the subtitles are out of the container, it does not identify them. How to force the identification of the subtitles when you are outside the container?
5 - When the film's audio is AAC, the TG can not identify the bitrate of the audio. Appears a question mark (?). How to force the TG to correctly identify the bitrate of the audio in AAC format ?
Ps. Use the latest version of ThumGen and my player is a Med500x2 with firmware 2.0.6
Thank you!
« Last Edit: April 26, 2012, 09:48:49 pm by Whooper » Logged
Sorry my English is not the best, I'm using the Google translator.
eentje
« Reply #319 on: April 26, 2012, 10:27:47 pm »
u can turn that off Smiley go thumbgen options, go to export image and remove checkboxes Smiley
the .tgmd file it the file thumbgen stores the data and settings u used for that template Smiley i generally keep that file Smiley why ?
when someone releases an update for a moviesheets or series sheets whatso ever Smiley u can use the option when u select the movies/series u want to process Smiley - manual mode  - semiautomaitc - automatic - im feeling lucky mode and "Create from metadata" when u use that option it will creat new sheets with same fanart and settings as the original sheet u make Smiley u can choose to use new imdb rating if u need Smiley
when there i a new template for the sheets creating the new sheets with mededata usually takes like 10 min while manually automic creating them takes 45 Smiley so its les time consuming Smiley
i dont think it can Smiley
5 - When the film's audio is AAC, the TG can not identify the bitrate of the audio. Appears a question mark (?). How to force the TG to correctly identify the bitrate of the audio in AAC format ? no idea about that Smiley
Thank you!
Dennis75
« Reply #320 on: March 14, 2013, 08:49:00 am »
Hi all!
Is there anywhere a walkthrough for Thumgen and the Mede8er (600X3D) ?
bye
Dennis
« Reply #321 on: March 14, 2013, 09:08:35 am »
You might want to try this one:
http://www.mede8erforum.com/index.php/topic,7114.0.html
And specific for Series I would advise now to use TVRename.
http://www.mede8erforum.com/index.php/board,149.0.html
Dennis75
« Reply #322 on: March 14, 2013, 10:55:20 am »
Thanks a lot, i will check it!
For Series is already use TVRename Smiley
Pages: 1 ... 20 21 [22]   Go Up
