Author Topic: ThumbGen  (Read 186491 times)
Offline thumbgen
  • ThumbGen's Developer
    • ThumbGen
Re: ThumbGen
« Reply #30 on: June 14, 2010, 11:44:31 am »
Too bad itīs static images.
I am producing static images :)  Can't be dynamic... to achieve the dynamic effect the player must "steer" the lower part.
Get ThumbGen!
If you like ThumbGen then buy me a coffee
Offline Voodoo
Re: ThumbGen
« Reply #31 on: June 17, 2010, 11:16:41 pm »
@ thumbgen, thanks very nice program. I tried YAMJ and YAMJ to Mede8er, but I prefer this. A bit slower but output is very nice.  ;D
Offline tachita
  • Guest
Re: ThumbGen
« Reply #32 on: June 17, 2010, 11:43:01 pm »
How can magnify the text?
Or depend by the used skin... ???
Offline wayne99
Re: ThumbGen
« Reply #33 on: June 18, 2010, 01:21:45 am »
i do it manually by editing the template skin xml file... :)  ..just look for "font" for the section you want to increase and increase its value....
save it and press the refresh button, it will be apply immediately....
i do that for the description part.... much easier to read.....
hope the developer can have a option to modify this on the program instead.....  :D
Mede8er with f/w V4 final HD included version(Jan 25th)
TV: Composite connection to Samsung TV(still no LCD yet...:( )...maybe in 2011
Content : Internal 2TB WD Cavier Green (mede8er formatted) - modded to ext3 partition
Network : Mede8er - LAN connection to TP-link WR1043ND for NAS/streaming
PC : Windows 7 connect wireless 300N to WR1043ND.
Offline thumbgen
    • ThumbGen
Re: ThumbGen
« Reply #34 on: June 18, 2010, 05:23:46 am »
When you feel  TG being slow PLEASE write down also your arguments: when is it slow? It is very important for me to optimize those areas. Use only needed collectors, switch off autopreview and it will get faster. There are so many things done automatically in the background..maybe u don't need all (4 full images are downloaded before results page being ready for example).
Regarding font... the complete output of ThumbGen is steered by the (XML) template you use. On wdtvlive.net there are tons of templates. As soon as I finish the main tasks remaining for TG I will start working on a full featured Templated Editor (integrated in TG). That will make life much easier ;)
Get ThumbGen!
Offline tachita
  • Guest
Re: ThumbGen
« Reply #35 on: June 18, 2010, 10:14:13 am »
yes indeed , the description part is very small , my eyes suffer if i read all description.......... ;)
editing xml isn't what i want, but sience others work also in this way......... i dont have nothing else to do.. :(
Offline thumbgen
    • ThumbGen
Re: ThumbGen
« Reply #36 on: June 18, 2010, 11:11:31 am »
Use the Templates Editor that comes with TVixie (tvixie.com); maybe it is easier than modifying xml (but not so fast for sure).
There are A LOT of templates available.. all of them have the font too small for you? Maybe we can push template authors to use bigger fonts, should be simple...
PS: @wayne99:  Are u sure u understood the concept behind ThumbGen? The developer of ThumbGen cannot add "an option" inside the app to make font bigger as the output is decided by the template that YOU choose :) That's the beauty of the templates-based concept.
« Last Edit: June 18, 2010, 11:20:45 am by thumbgen »
Get ThumbGen!
Offline tachita
  • Guest
Re: ThumbGen
« Reply #37 on: June 18, 2010, 11:23:10 am »
PS: Are u sure u understood the concept behind ThumbGen? The developer of ThumbGen cannot add "an option" inside the app to make font bigger as the result is decided by the template that YOU choose :) That's the beauty of the templates-based concept.
to use editor from another utility..........doesnţt sound that great.  ???
the concept behind the thumbgen .....yes i do...
but , when nobody like me will ask template creators to make bigger font ....... :-\  :-\  :-\
or the thumbgen creator to do a template editor.... :o
Offline thumbgen
    • ThumbGen
Re: ThumbGen
« Reply #38 on: June 18, 2010, 11:24:55 am »
Honestly I also think the font is a bit small on almost all templates... maybe authors have 50inch displays  ;D ;D
As soon as I come back from holiday I start working on a cool Templates Editor ;)  Every user will be able to make a template, that's my goal :)
Get ThumbGen!
Offline wayne99
Re: ThumbGen
« Reply #39 on: June 18, 2010, 11:46:37 am »
@thumbgen;
yeah...i understand the concept of thumbgen and template.....
i think my english is not that good, but you got my intention.....something like template editor integration will be good, instead me editing xml.... :-[
Thumbgen ids a great program...looking forward for your enhancement.... ;D
Offline bluntspoon
  • ...no one really knows...
Re: ThumbGen
« Reply #40 on: June 19, 2010, 07:21:17 pm »
Trying out ThumbGen v1.1.1
Liking it so far.
Fav Template = Ultimate Glass_Optional_SHEET
@TG I think you should look into your thread handling a little more, as your app seems to hang quite a lot.
Keep up the good work. (I would be more than happy to assist with Beta Testing)
Home Theater Setup:
Samsung LA40C650L1R
Mede8er MED500X2
Mede8er MED400X
Offline thumbgen
    • ThumbGen
Re: ThumbGen
« Reply #41 on: June 19, 2010, 07:53:58 pm »
Best u can do is to send me log.txt when u feel it is hanging ... theoretically should not hang :) ... Was it hanging during batch updating sheets from existing metadata? A log.txt after you make it hang will help a lot! (thumbgen [at] googlemail.com)
Thx for the feedback ;)
Get ThumbGen!
Offline bluntspoon
Re: ThumbGen
« Reply #42 on: June 21, 2010, 05:24:23 am »
Cool, I try and get that to you this evening.
Home Theater Setup:
Samsung LA40C650L1R
Mede8er MED500X2
Mede8er MED400X
Offline bluntspoon
Re: ThumbGen
« Reply #43 on: June 21, 2010, 07:57:39 pm »
Just emailed you the log...
Question: Does TG also do file/folder renaming?
Cheers
BluntSpoon
Home Theater Setup:
Samsung LA40C650L1R
Mede8er MED500X2
Mede8er MED400X
Offline thumbgen
    • ThumbGen
Re: ThumbGen
« Reply #44 on: June 21, 2010, 08:11:38 pm »
No, there's no renaming feature in TG. There are some very good free tools for renaming files/tv shows; would be a waste of time to reimplement them. (TheRenamer, TVRenamer, etc)
Get ThumbGen!
