Author Topic: Media library issues  (Read 1461 times)
Offline stevo1961
« on: July 05, 2018, 06:08:13 pm »
Hi guys,
Hopefully I'm in the right forum area.
I've noticed that the last 3 movies I've uploaded to my MED800X3D  have all got pixelated thumbnails and info pages. This is after I've run Y2M program and scanned the folder on the mede8er. The movies play perfectly  well but the library doesn't look right with these 3 thumbnails. I find it a tad annoying. I have carried out this procedure 1000's of times in the past with no problems until now.
Any advice would be appreciated
Steve
Re: Media library issues
« Reply #1 on: July 08, 2018, 05:42:06 am »
You need to update the firmware to the latest to resolve the corrupted images when scraping
V4.0.2 - 6April2016 -X3D Series - for MED1000X - MED800X - MED600X Patched 2
Latest firmware page
http://www.mede8erforum.com/index.php/topic,19488.0.html
Offline Tarpon1965
« Reply #2 on: July 08, 2018, 11:09:58 pm »
Steve, let me know if this fixes your issues as I started having the same issue a few weeks ago.  I'm certain I have been running the latest firmware, but I did try to update anyway, per Mede8er1's recommendation, and I tried to rescan, but the photos are still pixelated.  Knowing this unit is not being updated anymore, this may be the end of my using the 1000.  It has been a great unit since I purchased it.
« Reply #3 on: July 09, 2018, 04:03:51 pm »
Once you have installed -
You must delete the 'movie.name.xml' files in the Move folders that have corrupted images before scanning.
Offline Tarpon1965
« Reply #4 on: July 09, 2018, 09:16:54 pm »
Thank you, I will try that tonight.
Offline Tarpon1965
« Reply #5 on: July 14, 2018, 07:06:51 pm »
Mede8er1, this did work.  Thanks again for the help.
Offline Smrek
« Reply #6 on: July 29, 2018, 03:36:35 pm »
Where is the movie.name.xml file ?
Need to connect MED600X3D to PC?
Offline Reasons
« Reply #7 on: October 31, 2018, 04:49:42 am »
Offline velvet
« Reply #8 on: December 31, 2018, 05:06:54 pm »
this procedure does not help. I do not know what else. repeated image damage.   :-\
can you better specify the procedure?
« Reply #9 on: December 31, 2018, 05:21:27 pm »
The firmware is needed to prevent the issue occuring as new scrape is created. It does not fix old images with the problem. To force a new scrape the xml file created in the movie folder must be deleted. That is often done quicker with a PC.
Offline velvet
« Reply #10 on: January 01, 2019, 10:09:38 pm »
I have reinstalled the firmware v4.0.2 and deleted the xml file from the movie clip, but the problem remains.
Offline velvet
« Reply #11 on: January 02, 2019, 11:50:57 pm »
problem solved fw 4.0.2 patch 2  ;)
