Author Topic: question about remote med1000x3  (Read 1514 times)
Offline abdullah
« on: June 27, 2018, 05:54:14 pm »
hi
i have med1000x3
but in remote control  there is 2 icon Volume Up/Down
how i can control the volume ?
i try but is not work , the volume canít go up or down
‬iím watch movies but canít control the volume in remote, i just control the volume in remote tv
Offline Sodikana
Re: question about remote med1000x3
« Reply #1 on: August 07, 2018, 09:47:36 am »
We are looking for these data to fit. Which is very good we have come across.
Offline micron
« Reply #2 on: August 07, 2018, 02:50:05 pm »
Go to settings, and then to audio, at the bottom of that menu there is sommething like "fix maximum volume" ( don't now exact text i am dutch) set this to off. The volume should work fine now.
Offline Alogzasud
« Reply #3 on: September 10, 2018, 03:27:00 am »
I've tried to do you already.
Offline HenryDub
  • Helpful Contribution Status: +0/-5
« Reply #4 on: March 12, 2019, 09:01:11 am »
Just a suggestion, why does Cadillac not light the buttons on the Universal Remote System????
