Author Topic: Feedback for - YAMJ_To_Mede8er_Peter_Butler_V2.0.5mod_Shizzl_yamj2.10-b1a99a3  (Read 41991 times)
Offline sphinc70
Re: Feedback for - YAMJ_To_Mede8er_Peter_Butler_V2.0.5mod_Shizzl_yamj2.10-b1a99a3
« Reply #15 on: September 05, 2018, 10:50:56 PM »
Once again, thanks Gabriele for your continued support. The new fix works perfectly. I just ran a batch of 25 movies and it didn't miss a beat.
Cheers
Sphinc70
Offline leftygt
« Reply #16 on: September 08, 2018, 12:45:31 PM »
not working for me....still no cast... :( :(
Offline elton-77
« Reply #17 on: September 08, 2018, 12:56:15 PM »
Strange, it's working flawlessly for me on both desktop and Laptop YAMJ installations.
Did you follow the instructions given? eg after downloading the fix file ...
Instructions - Find the directory where you installed Y2M (on my computer it's C:\Program Files (x86)\YAMJ_To_Mede8er_Peter_Butler_V2.0.5mod_Shizzl_yamj2.10-b1a99a3), and navigate into the "lib" subfolder. The "lib" subfolder should contain "yamj-2.10-SNAPSHOT.jar"; replace this file with the new file, and you're set!
Offline leftygt
« Reply #18 on: September 08, 2018, 01:45:33 PM »
yeah, replaced the "snapshot" file in the Ilb folder with the downloaded one, ran yamj...no change at all?
Offline leftygt
« Reply #19 on: September 08, 2018, 02:55:30 PM »
got it sorted, needed to restart the pc....thanks !!! :D :D
Offline elton-77
« Reply #20 on: September 08, 2018, 03:11:37 PM »
Glad you've sorted it :)
Offline pipo10
Thanks for the work !!
Offline rommy66
I'm not getting: genre, plot and rating :(((
Is there a way to fix it?
Offline elton-77
What version of firmware are you using on the Mede8er ?
Offline rommy66
The latest one: UPDATE 1 Sept 2018 by Gabriele Giuseppini
Offline elton-77
So you have the latest version of YAMJ software but are you running the latest version of firmware on your Mede8er?
Offline rommy66
Why firmware on Mede8er is important for YAMJ? Mede8er reading what I save on his HDD so that doesn't matter how I prepare movie folder :))
Check this picture to see what I'm talking about:
Offline elton-77
My bad ... wasn't thinking. Here's a couple of things you can try
Q1. Have you totally cleared the original YAMJ before installing the latest? Have you tried a re-install of YAMJ?
Q2. Have you tried deleting the movie entries in  the Jukebox folder relating to the films in question and then running YAMJ?
Q3. Have you cleared all images in the movie folder before running YAMJ?
If you have and it still does not scan correctly I don't know what else to suggest.
Offline Buff
How is the old version working for everyone, I just bought a new laptop and I need to install the latest version, did some search found this link
http://jenkins.omertron.com/job/YAMJ/lastBuild/com.moviejukebox$yamj-distribution/
Did anyone test this version out?
Cheers
Offline elton-77
Cheers
The release issued here after considerable effort by Gabriele works very well for me and others I suspect ...  otherwise there would have been posts regarding problems.
I've not looked for an alternative version as I've not needed to.
Let us know how you get on with your newly found link.
