Author Topic: Pixelated Jukebox Folder Images - Why?  (Read 3467 times)
Offline Arcticsplash92
« on: May 05, 2018, 12:43:38 pm »
I have MED1000X3D and it saves the folder images fine to hard drive or USB drive but when doing the same when using an NAS drive over ethernet, it results in pixelated images for the folder and fanart on the Jukebox view. Anyone know why this might be? I am saving images by using the edit function when highlighting the film folder in the Jukebox view.
Re: Pixelated Jukebox Folder Images - Why
« Reply #1 on: May 06, 2018, 01:15:59 pm »
Are you using NFS or Samba? Have you turned on file versions in its journal? The pixelation fixing process results in a second version of files. Most people don't have version management, so there is only ever one file.....the latest.
« Last Edit: May 06, 2018, 02:18:14 pm by jer1956 »
Offline marech_jean
Re: Pixelated Jukebox Folder Images - Why?
« Reply #2 on: May 12, 2018, 08:19:38 am »
hello
I have the same problem wit my MED600X3D.
When I'm using the NAS to see movies, the pictures (JPG) appears pixellised and not when I'm using the the local disk...
Is there a setting ?
You said : "Have you turned on file versions in its journal? The pixelation fixing process results in a second version of files" I did'nt undertstand what  you want to say...
Jean
