Author Topic: Corrupted pictures after scratching - single movies  (Read 13880 times)
Offline GaitJean
« Reply #150 on: March 14, 2018, 04:11:11 pm »
Is there any chance we get a similar patch for X2 firmware?
Verstuurd vanaf mijn Moto G (4) met Tapatalk
Offline GaitJean
« Reply #151 on: March 14, 2018, 04:12:16 pm »
Is there any chance we can get this patch also for X2 firmware?
  • Helpful Contribution Status: +100/-24
« Reply #152 on: March 14, 2018, 04:22:45 pm »
We looking at the X2 firmware to see if its possible to patch and if workable we will do it. I have no idea of the timeline at this point.
Offline micron
« Reply #153 on: March 15, 2018, 12:26:14 am »
It would be nice to have the patch for the X2 also. Thanks to seeing into it.
We will wait and see.
« Reply #154 on: March 15, 2018, 10:13:16 am »
As I said earlier, the Chinese sub contractor has the SDK. This is a true patch. An engineer at Mede8er-EU went into the firmware and modded it with an editor. This is not something you can do with every remaining problem. It was always a case of it would be fixed if it could.
Offline dntaylor
« Reply #155 on: March 15, 2018, 07:16:45 pm »
A HUGE BIG thanks to you guys for this....works like a charm. ;) ;)
Offline sayon
« Reply #156 on: March 18, 2018, 08:46:57 am »
Hello,
installed the patched firmware ... it's perfect.
Thanks to the whole community for help.
Greetings ;D
Offline forenuser
« Reply #157 on: March 18, 2018, 10:29:54 am »
If I try to execute Internet -> Internet the player crashes and shows just a white screen. It is necessarry to remove the power supply to reset the player. Is this behavior caused by the patch?
Offline raregoblin
« Reply #158 on: March 18, 2018, 01:46:50 pm »
Thank you from the Goblin - I appreciate the work you guys have done fixing this error. Hats off to you mates.
Offline juriel
« Reply #159 on: March 20, 2018, 08:24:41 pm »
 x2 patch would be great
« Reply #160 on: March 24, 2018, 11:34:26 am »
Offline dntaylor
« Reply #161 on: March 25, 2018, 12:48:18 pm »
Has anything else been changed with the update patch for the MED800X3D other than the corrupted pics issue?, because I can no longer use the Android app 'DroidM83'. Since I have installed the patch it will no longer update the Jukebox which makes it unworkable except the remote on it that still works. I used this app a lot for playing my music with not having to put the TV on.
« Reply #162 on: March 25, 2018, 01:57:29 pm »
Make sure you have turned Net API back on in setup. Then power cycle everthing on the netwotk, including the router,  to clear out all DNS caches.
Offline dntaylor
« Reply #163 on: March 25, 2018, 04:33:54 pm »
Thanks for your fast reply, I have checked and reset everything but the problem still their, the funny thing is the remote works on the app fine, it just won't update the jukebox so you can't use it for accessing your media. The Mede8er smart remote app works fine but I do prefer the DroidME83 app for navigating through my music.
« Reply #164 on: March 25, 2018, 05:35:50 pm »
Was it still working with the previous firmware? App developers can chose to get scrape direct from the source database and end up with the same problems with server changes as the player.
