Author Topic: Corrupted pictures after scratching - single movies  (Read 13837 times)
Offline japanwings
« Reply #135 on: March 11, 2018, 08:45:06 am »
Works perfect, thank you for fixing !
Offline rockabulli
« Reply #136 on: March 11, 2018, 12:04:52 pm »
It works!! :) Thanks a lot!
Offline Martin04
« Reply #137 on: March 11, 2018, 01:52:14 pm »
it is possible to optimized the V4.0.0 - 2Jan2015 firmware with this fix ?
http://www.mede8erforum.com/index.php/topic,15654.0.html
after that firm you changed the handling of the mp4 files,
it is no possible to fast forward
the 4.0 firm work like charm, but now are the problem with the scrapper
Offline micron
« Reply #138 on: March 11, 2018, 02:49:23 pm »
I am using last firmware 4.02 patched of yesterday and the mp4 files can be played fast forward, no problem.
Before, I had also no problems with mp4 files.
  • Helpful Contribution Status: +100/-24
« Reply #139 on: March 11, 2018, 04:22:06 pm »
I am using last firmware 4.02 patched of yesterday and the mp4 files can be played fast forward, no problem. Before, I had also no problems with mp4 files.
Same result my side.
Offline titi35
« Reply #140 on: March 11, 2018, 04:43:00 pm »
Bonjours Ça marche pas pour moi j'ai perdu la fontion Scrape et ca Scan dans le vide
Offline deadmonkey
« Reply #141 on: March 11, 2018, 08:16:27 pm »
Pls check updated patched firmware that fixes the movie scraper images from tmdb
http://www.mede8erforum.com/index.php/topic,19465.msg116404.html#msg116404
You've made me very happy, thanks!
That's three MED600X3Ds that will benefit from your fine work :)
Offline maslov
« Reply #142 on: March 12, 2018, 06:48:19 am »
What about the X2 firmware?
Verstuurd vanaf mijn 6055K met Tapatalk
Offline Fallen69
« Reply #143 on: March 12, 2018, 11:02:03 am »
Thank you very much, it works after update.   :) :) :) :) :) :)
Offline titi35
« Reply #144 on: March 12, 2018, 07:33:59 pm »
j'ai relancé la mise a jour et Ça fonctionne un grand merci  :) :)
Offline mattbaron
« Reply #145 on: March 13, 2018, 05:48:55 pm »
I have just updated the firmware but am still getting the same issue, anyone have any suggestions ?
Offline micron
« Reply #146 on: March 13, 2018, 06:30:29 pm »
Dit you use the patched version? Because then it should work well.
You have to update with the emergency  method.
Download the patched file, unpack it to the root of a usb stick. Turn the mede8er off and put the usb-stick into the usb-port, then push the power on button on the mede8er for about 15 seconds then release the button and let the mede8er do his work.
« Last Edit: March 13, 2018, 06:37:51 pm by micron »
Offline mattbaron
« Reply #147 on: March 13, 2018, 07:12:11 pm »
Yup done that and the system says I am running the correct version, also deleting the xml and re scanning makes no difference to the image.
Cheers for the answer
Offline daltimor
« Reply #148 on: March 13, 2018, 09:13:09 pm »
yuppi just done the patch all working fine. Thank you for your work guys !!! Mede8er is still the greatest media player  ;)
Offline deadmonkey
« Reply #149 on: March 14, 2018, 01:16:11 pm »
You saw it do the update, where it counted up the percentage?
I've done two Mede8ers thus far and both have gone from fully experiencing the issue to being resolved.
I didn't remove the xml file for my handful of broken titles, just did a edit, rescan and save for each.
