Author Topic: Yamj will not find any movies  (Read 1109 times)
Offline chasrog
« on: January 08, 2018, 05:07:37 pm »
Hi
Yamj will not find any movies even older ones.
It had worked OK. I have uninstalled and reinstalled but to no avail.
Any Ideas
Re: Yamj will not find any movies
« Reply #1 on: January 09, 2018, 01:29:32 pm »
Support for pre-Arm methodology is fading away. Too many are now running Kodi on arm based h265/4K players. As long as the Kodi scraping is kept up to date, they are not bothered.
Offline mike_carton
  • Helpful Contribution Status: +10/-1
« Reply #2 on: January 09, 2018, 02:56:18 pm »
YAMJ is hosted on github at https://github.com/YAMJ/yamj-v2/commits/master
A developer called Omertron posted an update as recently as April 2017. May be someone there can help.
Offline chasrog
« Reply #3 on: January 10, 2018, 12:28:01 pm »
Hi
I managed to go into settings and changed a number of items to TRUE and some Fanart and folders etc appeared but not on all movies
Offline elton-77
« Reply #4 on: February 08, 2018, 05:25:23 pm »
Not sure if this will help you but:
RAYJAY posted a newer version of YAMJ. I have installed it and can confirm it works beautifully to correct Java issues and IMDB scoring corruptions. In my case it also corrected the character set corruptions I was getting. So a happy chappy :)
http://www.mede8erforum.com/index.php/topic,18581.0.html#msg114395
Offline tonylogin
« Reply #5 on: February 11, 2018, 05:38:28 pm »
Trouble downloading from that site.
Mede8er 500X
Firmware: 4Beta5
PC: Win 7 Home Premuin
Offline elton-77
« Reply #6 on: February 11, 2018, 06:27:27 pm »
Really? Workes fine for me ... and just tried it again.
1. Click Slow Download
2. Enter the code shown to Verify the User
3. Press Download.
Done this a few times now and never any problem.
