Author Topic: Med800x 3d remote problem (fixed)  (Read 304 times)
Offline silotas
« on: December 13, 2017, 04:28:01 pm »
Hi!
Recently i experienced a problem with my remote control. The upper left blue light kept on flashing and i could not give any command with it. I changed batteries but nothing happened. The solution came after i hard pressed/moved all the remote buttons. I guess that a button stack and after i hard pressed it it came back to its original position. Hope that helps if anyone has the same problem!
