Author Topic: Adding Custom Genre Art To Favourites  (Read 221 times)
Offline vincez28
« on: December 10, 2017, 05:56:27 am »
hey Guys so on the user manual it shows a way to add custom genre art to the favorite folders. it says:
Make a folder 'Genre' and copy up to max 50
png genre covers into this folder. 1:1 size is 117 x 172 pixels but 156 x 233 pixels work ok as well.
Copy the 'Genre' folder to the Skin Folder. Focus on the Skin folder and press 'Menu' button
and select 'Set to Skin' option.
How do I get into the skin folder to add this new Genre folder? and by adding this new genre folder will that eliminate the genre icons already being used for the favorites folders?
thanks,
Vince
MED800X3D
Onkyo TX-NR 636
Samsung 65" 3DTV-(UN65H7150)
Synology DS415+
Offline vincez28
Re: Adding Custom Genre Art To Favourites
« Reply #2 on: December 10, 2017, 03:28:39 pm »
so how do I flash the folder to the memory? do I hook up the mede8er to the pc? can I view the "genre" folder over network? I already have the default icons I will delete some of the ones Im not using and replace with some custom ones that I will use.
thanks,
Vince
MED800X3D
Onkyo TX-NR 636
Synology DS415+
Offline vincez28
« Reply #3 on: December 17, 2017, 03:40:08 pm »
hey Jer1956, I figured it out. all I had to do was add a folder on my NAS and point to it through the med800 and click on set to skin. really easy not sure why there is such a big right up on that when its that easy.
anyways thanks as always,
Vince
MED800X3D
Onkyo TX-NR 636
Synology DS415+
