Author Topic: 'usb device not recognised'  (Read 383 times)
Offline ivangash@hotmail.com
« on: November 11, 2017, 11:26:12 am »
'the last usb device you connected to this computer malfunctioned and windows does not recognise it'
this is the message im getting to my brand new med800x3d with wifi and factory installed 3tb harddrive bought directly from Mede8er. i have been advised all firmware is up to date.
i followed the instructions in the user manual but still cannot connect.
Please Help
Re: 'usb device not recognised'
« Reply #1 on: November 11, 2017, 11:46:48 am »
im on windows 10.
starting to think i bought a jokeshop overly priced box.
already spoken to numerous people in tech support.
need help
« Reply #2 on: November 12, 2017, 10:08:28 am »
Send it back. If you bought it thinking it was 2017 technology you will have endless frustrations. Only those who want an additional player should get them. And in my opinion they should now be classed as surplus stock by retailers, sold cheaply with no support.
« Reply #3 on: November 12, 2017, 06:01:47 pm »
All i want to do is watch and store movies, the same with family photos and videos. As a moderator are you an employee of Mede8er? Technical support?
« Reply #4 on: November 12, 2017, 06:04:18 pm »
This is a User Forum. The Mods are experienced users with a Systems background. We can raise issues with Sanji if important enough.
« Reply #5 on: November 12, 2017, 06:37:53 pm »
Thanks for your reply...im already out of pocket for numerous phone calls to holland, regarding a number of issues and im in the position now where i dont know what to do with the item. Ill call them tomorrow to try and resolve the issue. Is there any technical advice you can give me?
« Reply #6 on: November 12, 2017, 07:05:21 pm »
The issue is as people upgrade around it, it has issues connecting to modern equipment. PC's , USB enclosures...all have issues. It really isn't worth the hassle if you have just got it.
The suggested workaround when use blue cable slave mode is hot dock. Turn on, then plug in the blue cable.
« Reply #7 on: November 12, 2017, 07:21:21 pm »
sorry dude? come again?
« Reply #8 on: November 12, 2017, 07:27:50 pm »
To connect like a USB Enclosure the blue socket is used, not the black ones. Hot Docking means power up the player before connecting by the blue socket and cable.
« Reply #9 on: November 12, 2017, 07:42:26 pm »
Thats what i did.....blue cable..same message
"Usb Device not recognised"
turning the thing on and off is so slow as well.
I dont understand is the company from Holland or south africa, as that other company makes all car electronics?
« Reply #10 on: November 12, 2017, 07:50:00 pm »
Mede8er are brand of Sanji Electronics based in South Africa. They are only an OEM who gets products made in China to their specification.  They have not had any made in two years.  The X3D is five years old!
It sounds like  the 1186 chip doesn't like working with your PC.
« Reply #11 on: November 13, 2017, 08:43:57 am »
You have formatted the drive using the player GUI? This should be done twice as the first just erases the Partition System if it's the wrong one.
And you have moved the player to the PC and have it no longer using HDMI?
These instructions are in the  online Manuals and guides. Some do think it must be plug'n'play and must do what a reasonable person might expect. It doesn't!
« Last Edit: November 13, 2017, 09:11:11 am by jer1956 »
« Reply #12 on: November 13, 2017, 06:04:12 pm »
you were right...it wasnt formatted! im not technical at all...most of this stuff is lost on me!
anyway im uploading my stuff at the moment so fingers crossed!
the v3 manual is very technical for me so i will be stumbling through the whole process...so ill be back!!
« Reply #13 on: November 13, 2017, 07:30:42 pm »
The point is drives are weight. Sanji ship them without drives. Unformatted drives are then fitted on arrival in each country.
« Reply #14 on: November 13, 2017, 08:01:27 pm »
are they constantly developing their software? or as you said 2015!
