Author Topic: 500X2 won't play any movies  (Read 629 times)
Offline beginnersluck
« on: October 07, 2017, 11:34:35 am »
I just bought a 500X2, so I installed a hard drive (formatted NTFS), installed the latest version (V3.05) and began to copy movies to it (from USB).
Then, I wanted to test it, and not one movie is playing.  They are on the HDD, because I checked by hooking the X2 to my PC (and they are playing through PC too).
When I try to play it, it says "folder empty", but when I hook it up to my pc, all files are there...
Why does it not want to play any movies on the X2?
So, what am I to do?
« Last Edit: October 07, 2017, 12:42:30 pm by beginnersluck »
Offline rommy66
Re: 500X2 won't play any movies
« Reply #1 on: December 23, 2017, 06:09:37 pm »
I guess that you formated your HDD on the PC and then install it to your MED500X2.
You MUST format you HDD via MEDE8ER to be able to access your media files on that HDD. Reformat HDD using MEDE8ER and then copy again movies, and 99.9% everything will work fine ;)
