Sro
Offline
« Reply #30 on: May 13, 2010, 09:17:02 am » |
Thanks for the info - I thought as much - the extra features seemed good but Im getting an internal HDD soon so will upgrade then. Cheers
« Reply #31 on: May 13, 2010, 10:05:43 am » |
2.1.0 should work fine without HDD installed, so you can give that a try
Sro
Offline
« Reply #32 on: May 13, 2010, 11:54:23 am » |
2.1.0 should work fine without HDD installed, so you can give that a try  Thanks - Ill give it a try and see if I get the invalid files again. Gotta say the responses and support on here is bloody champion!
marten72
Offline
« Reply #33 on: August 07, 2010, 05:36:58 pm » |
Hi! I feel the need to open this again since I have the same problem as Wilmer. I just recieved my player and it has v 2.10. I only have an external HDD. It will play some of my mkv:s but almost half is marked as invalid files. I tried to remux with mkvmerge but then I only get audio and subtitles but no picture! Oh, and they all play perfectly in my mac. I have tried to search this forum but havent found a solution yet. Maybe I should just return it or is there an solution?
tachita
Guest
Offline
« Reply #34 on: August 07, 2010, 05:45:33 pm » |
Try to post a log from MediaInfo software, maybe the video codec isn't supported .
marten72
Offline
« Reply #35 on: August 07, 2010, 10:47:40 pm » |
Here are 2 examples:
#1
General / Container Stream #1 Total Video Streams for this File.................1 Total Audio Streams for this File.................1 Total Subtitle Streams for this File..............2 Video Codecs Used.................................AVC Audio Codecs Used.................................AC3 SubTitle Codecs Used..............................UTF-8 / UTF-8 Available Sutbitle Languages......................English / English File Format.......................................Matroska Play Time.........................................1h 33mn Total File Size...................................7.95 GiB Total Stream BitRate..............................12.1 Mbps Encoded with......................................mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26 Encoding Library..................................libebml v0.7.7 + libmatroska v0.8.1 Video Stream #1 Codec (Human Name)................................AVC Codec (FourCC)....................................V_MPEG4/ISO/AVC Codec Profile.....................................High@L4.1 Frame Width.......................................1 920 pixels Frame Height......................................1 072 pixels Frame Rate........................................23.976 fps Total Frames......................................135216 Display Aspect Ratio..............................16:9 Scan Type.........................................Progressive Color Space.......................................YUV Codec Settings (Summary)..........................CABAC / 3 Ref Frames QF (like Gordian Knot)............................0.232 Codec Settings (CABAC)............................Yes Codec Settings (Reference Frames).................3 Video Stream Length...............................1h 33mn 59s 640ms Video Stream BitRate..............................11.5 Mbps Bit Depth.........................................8 bits Video Stream Size.................................7.37 GiB (93%) Video Encoder.....................................x264 - core 60 r928M 4816918 Video Encoder (Settings)..........................cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.000000 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=24 / keyint_min=1 / scenecut=40(pre) / rc=2pass / bitrate=11461 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=38000 / vbv_bufsize=30000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00 Video Stream Language.............................English Audio Stream #1 Codec.............................................AC-3 Codec (FourCC)....................................A_AC3 Audio Stream Length...............................1h 33mn 59s 648ms Audio Stream BitRate..............................640 Kbps Audio Stream BitRate Mode.........................CBR Number of Audio Channels..........................6 Audio Channel's Positions.........................Front: L C R, Side: L R, LFE Sampling Rate.....................................48.0 KHz Audio Stream Size.................................430 MiB (5%) Audio Stream Language.............................English Subtitle Stream #1 Language..........................................English Format............................................UTF-8 Codec ID..........................................S_TEXT/UTF8 Codec Info........................................UTF-8 Plain Text Subtitle Stream #2 Language..........................................English Format............................................UTF-8 Codec ID..........................................S_TEXT/UTF8 Codec Info........................................UTF-8 Plain Text
#2
General / Container Stream #1 Total Video Streams for this File.................1 Total Audio Streams for this File.................1 Total Subtitle Streams for this File..............2 Video Codecs Used.................................AVC Audio Codecs Used.................................AC3 SubTitle Codecs Used..............................ASS / ASS Available Sutbitle Languages......................English / Romanian File Format.......................................Matroska Play Time.........................................51mn 10s Total File Size...................................2.18 GiB Total Stream BitRate..............................6 109 Kbps Title (Tag).......................................Planet.Earth.EP01.From.Pole.to.Pole.2006.720p.HDDVD.x264-ESiR Encoded with......................................mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55 Encoding Library..................................libebml v0.7.7 + libmatroska v0.8.1 Video Stream #1 Codec (Human Name)................................AVC Codec (FourCC)....................................V_MPEG4/ISO/AVC Codec Profile.....................................High@L5.1 Frame Width.......................................1 280 pixels Frame Height......................................720 pixels Frame Rate........................................23.976 fps Total Frames......................................73608 Display Aspect Ratio..............................16:9 Scan Type.........................................Progressive Color Space.......................................YUV Codec Settings (Summary)..........................CABAC / 9 Ref Frames QF (like Gordian Knot)............................0.256 Codec Settings (CABAC)............................Yes Codec Settings (Reference Frames).................9 Video Stream Length...............................51mn 10s 70ms Video Stream BitRate..............................5 660 Kbps Bit Depth.........................................8 bits Video Stream Size.................................1.98 GiB (91%) Video Stream Title................................Planet Earth - EP01 - From Pole to Pole Video Encoder.....................................x264 - core 54 svn-635M Video Encoder (Settings)..........................cabac=1 / ref=6 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=0 / mbaff=0 / bframes=4 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5660 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.5:18.0 Video Stream Language.............................English Audio Stream #1 Codec.............................................AC-3 Codec (FourCC)....................................A_AC3 Audio Stream Length...............................51mn 10s 72ms Audio Stream BitRate..............................448 Kbps Audio Stream BitRate Mode.........................CBR Number of Audio Channels..........................6 Audio Channel's Positions.........................Front: L C R, Side: L R, LFE Sampling Rate.....................................48.0 KHz Audio Stream Size.................................164 MiB (7%) Audio Stream Title................................AC3 5.1 Audio Stream Language.............................English Subtitle Stream #1 Language..........................................English Format............................................ASS Codec ID..........................................S_TEXT/ASS Codec Info........................................Advanced Sub Station Alpha Subtitle Stream #2 Language..........................................Romanian Format............................................ASS Codec ID..........................................S_TEXT/ASS Codec Info........................................Advanced Sub Station Alpha
marten72
Offline
« Reply #36 on: August 07, 2010, 11:31:10 pm » |
Hey!
I downgraded to v 1.22a and now I can see all my movies! Weird. Something has gone wrong somewhere in the updated firmware. Maybe it can be fixed so even I can enjoy the latest firmware with all the bugfixes. Anyone knows about this problem?
tachita
Guest
Offline
« Reply #37 on: August 07, 2010, 11:44:04 pm » |
What i see in your logs is nothing out of common. First file, it has i higher bitrate - but not too high, should give you problem only if you play it from flash usb drive ; The second file is more problematic- it has 9 reframes and i think is a experImental video file, not very sure. If i an not tricked , your files should work fine on M8R; dont find a plausable reason for such behaviour . Maybe a bad mux proces or bad encoding... The second file i have it also, with same parameters , except 9 reframes.
marten72
Offline
« Reply #38 on: August 08, 2010, 12:04:11 am » |
Ok, but the problem is they don't play in v 2.10 but I had no problem playing them when I downgraded to 1.22 a. That is kind of strange dont you think. I dont want to stay with 1.22 but I rather watch my movies than not. I am sorry to miss out of the bugfixes though.
tachita
Guest
Offline
« Reply #39 on: August 08, 2010, 12:26:47 am » |
From v2.1.0 and v3.0.4 is a little difference, don't you think? To be honest, i am one of very few that never try the v2.1.0 fw version...it didn't pass trough beta testers stages...
Volfeed
Offline
« Reply #40 on: August 08, 2010, 05:34:26 am » |
I also had the same problem with marten72. Tried to reencode the audio from AAC to AC3 since the output is so soft and my receiver cannot decode to 5.1 ch audio with AAC. Used the latest MKVMerge to merge the video + audio + subs to an MKV file but only subs and audio is played.
Tried upgrading to 3.04, nothing works.
Tried again, this time I just demux with MKVextract and remux with MKVMerge to check any potential mistakes during reenconding. The remuxed file played fine onmy PC but I got no video on Mede8er.
Should I rollback the firmware like marten? Is that even possible?
wayne99
Offline
« Reply #41 on: August 08, 2010, 06:53:37 am » |
 finally i got 2 mkv file that doesn't play with mede8er yesterday... it plays without problem on PC checking with mediainfo doesn't reveal anything when compare to my other playable mkv file. then, when i use mkvmerge to load the "non-playable" mkv file, there is this additional TAG being added in there in addition to the video and audio file. I take risk and deselect it and remux again, and voila...it plays in mede8er.... this is my recent experience, so perhaps it can give u an idea to just strip it to just audio and video for the mkv merge...see it works for ur case... i'm a happy man again... mede8er fail to dissapoint me...hehehe....
Mede8er with f/w V4 final HD included version(Jan 25th) TV: Composite connection to Samsung TV(still no LCD yet...  )...maybe in 2011 Content : Internal 2TB WD Cavier Green (mede8er formatted) - modded to ext3 partition Network : Mede8er - LAN connection to TP-link WR1043ND for NAS/streaming PC : Windows 7 connect wireless 300N to WR1043ND.
Volfeed
Offline
« Reply #42 on: August 08, 2010, 04:00:52 pm » |
Tried again on another machine running Win XP (the one in previous post is running Win 7), and the MKV can be read!  Well, although the muxing will be quite slower, at least the media file can be read.
« Reply #43 on: August 08, 2010, 10:22:01 pm » |
Tried again on another machine running Win XP (the one in previous post is running Win 7), and the MKV can be read!  Well, although the muxing will be quite slower, at least the media file can be read.  Most people using WinxP will have installed something which will play MKV's. MKV is not supported "out of the box" with Windows7. I installed Divx Plus to get MKV support.
the-osiris
« Reply #44 on: August 09, 2010, 05:10:41 am » |
I never have problem playing media from my pc, since I use K-Lite Mega Codec ..  Although some of my media was unable play in mede8er  but it's not the player fault, some was poor encoded, some needs re-muxing, and some was corrupted ...
