Author Topic: TV Scraper issue. Fixed. December 2017.  (Read 52749 times)
Offline Dolus
Re: TV Scraper issue. Fixed. December 2017.
« Reply #90 on: December 14, 2017, 10:04:14 AM »
jacou031 & Cinoche
You can answer this question yourself. If the TV scraper is not working then you have nothing to lose by just trying.
I think my advice was lost in translation. I did not mean update the bootloader/firmware but just try the scraper. As for rebooting your player first, that just means switching it off then on again, which you likely do everyday you use it.
« Last Edit: December 14, 2017, 10:15:33 AM by Dolus »
Offline deja
« Reply #91 on: December 19, 2017, 07:36:26 PM »
Thank you for fixing - on whichever way!
In my case the way over Edit doesn't work.
If I choose Scan Folder it works.
Individual editing on this way isn't possible, but thats okay.
« Reply #92 on: December 30, 2017, 06:30:11 AM »
We have updated the TV Series scraper app to take care of TV Series folder names with '.' like 'The.X.Factor.UK'. To use the new app just reboot your X3D and it will updated automatically. The 'Edit' function is working but unfortunately when doing a 'Scrape' and then selecting the correct TV Series name it cannot show the fanart or poster due to the tvdb changes. The good news is if you select the correct TV Series after the 'Scrape' and then 'OK' then select 'Save' it will work correctly and download all the required images and xml files as in the past.
Offline mike_carton
  • Helpful Contribution Status: +11/-1
« Reply #93 on: December 30, 2017, 09:52:35 PM »
Given the amount of work some community users have put in for free to produce and modify tools like Thumbgen, Aggregate Mede8er Jukebox Manager, Yadis, YAJM, Y2M, Yadis2M, TVRename, the Net API apps and so on, it seems to me that people will step up and fix lingering defects in the code if it made open source. I'd not be surprised if people found ways to add new functionality, made it more efficient and more extensible.
« Reply #94 on: December 31, 2017, 09:00:59 AM »
The code is generated via a proprietary Realtek SDK owned by the software subcontractor. Very little is opensource, and that has to have added libraries  via the SDK to work. The bulk of the outstanding issues are in those very old libraries that Realtek have no interest in fixing.  Older models had their code modded via patching the compiled code using cut and paste from other compiled code taken from other makes. Secure boot stopped that.
« Last Edit: December 31, 2017, 09:29:43 AM by jer1956 »
Offline Archer_VC10
« Reply #95 on: January 26, 2018, 07:18:51 PM »
I just had a go at using the TV series scraper again but no luck yet. I have updated the firmware to the latest 4.0.2 from April 2016 to see if that would make a difference (was using the November 2015 one up to today). I have tried the 'edit' option on a single folder with a series in it but when I do and select 'scrape', a window pops up with zero results. I have now selected 'Scan Folder' on the complete TV Series folder and it is doing something, I just hope that it doesn't mess up the images and files that were already there.... it may take a while to finish so I'll report back when it has completed.  ;)
Offline Archer_VC10
« Reply #96 on: February 08, 2018, 08:54:16 PM »
Forgot to reply earlier, but no luck yet. Running 'scan folder' has not changed anything, the series without images etc are still showing as icons only. Any tips?
Offline mike_carton
« Reply #97 on: February 08, 2018, 11:25:52 PM »
PC-based scraper TVRenamer is much more than just an effective scraper.
Offline realmode
« Reply #98 on: March 07, 2018, 05:44:51 PM »
Hi there,
I played last night with ThumbGen and tiny media manager.
After 3 hours I give up, I run into a bull[CENSORED] issue.
On my movie wall, some folders display the fanart image instead of movie poster image.
Anybody with the same issue? Any available solution?
Thanks.
Offline realmode
« Reply #99 on: March 07, 2018, 08:50:54 PM »
Hi there,
Thanks.
Issue solved with yaDIS v2.3
Offline aorfix
« Reply #100 on: March 10, 2018, 12:10:01 AM »
How could you scrape tv shows? I can only search for movies  :(
Offline realmode
« Reply #101 on: March 10, 2018, 03:28:09 PM »
I don't watch tv shows.... but you can manually inject pictures in every folder/tv show.
This was the only way I can have a normal wall.
Cheers.
Offline chutor
« Reply #102 on: March 04, 2019, 10:10:48 AM »
Still having problem! Each time I try to edit a series the system hangs up.
Step by step: Select "Menu" - "Edit" and then the mede8er hangs up and I have to unplug the power supply. Tested it again with movies and it works fine. Any idea? I had the issue last year, update to the new SW version, but now the issue is back again!  :-[
Offline moodybluesman
« Reply #103 on: October 08, 2019, 06:53:02 PM »
Unfortunately my MED800X3D won't scrape any TV series or movies anymore, I haven't loaded any videos on the hard drive for a few months but everything worked fine the last time. I thought this issue had been fixed, or is this some other problem? I was actually going to buy another 800 as I thought it was an excellent piece of kit for my requirements, but without the scrape function I've put that plan on hold for now.
Will we ever get the scrape feature back? :-\
« Reply #104 on: October 15, 2019, 11:33:12 PM »
I've tried Kodi, TV Rename and yaDIS without success. The only one that I could get to work was Kodi but when I export the files there is no TV about episode xml. Is there any way around this scraping issue? I've spent hours  experimenting with software and trying to load information manually without success, any advice would be appreciated.  :(
« Last Edit: October 19, 2019, 06:37:34 PM by moodybluesman »
