Author Topic: TV Scraper issue. Fixed. December 2017.  (Read 21057 times)
Offline elton-77
Re: TV Scraper issue. August 2017.
« Reply #45 on: November 16, 2017, 08:48:56 am »
Offline kazza61
« Reply #46 on: November 16, 2017, 10:45:22 am »
I use http://www.kvibes.de/mediaelch/
The link is all in German but I presume the app can be set to English? Can it also be integrated in the X3D?
Offline elton-77
« Reply #47 on: November 16, 2017, 12:06:43 pm »
The downloaded app is in English.
I doubt it can be integrated with the X3D; but it can be used in conjunction with the hard drives used with the Mede8er when they are attached to a PC.
At least that is how I intend to use it. Initial testing of TV series returned great results.
Offline kazza61
« Reply #48 on: November 16, 2017, 12:21:38 pm »
Thanks for that - will give it go!
Offline felho001
« Reply #49 on: November 19, 2017, 12:22:24 pm »
Hi it is not work to mede8er. When I exported tv shows folder fanart episode jpeg just upload 1 new map.
Offline LarryM8
« Reply #50 on: November 19, 2017, 01:07:31 pm »
I am using TVRename (current version: https://groups.google.com/d/msg/tvrename/AxTKFA6fpKQ/OFtSdoMeBAAJ) and it is working fine.
When you installed it, first go to Options -> Preferences -> Media Center and select which files you want to be created. Then follow the Quickstart Guide in the Help menu.
Offline felho001
« Reply #51 on: November 19, 2017, 05:18:17 pm »
Ok but I have OSX not windows user....
« Reply #52 on: November 19, 2017, 05:47:07 pm »
Intel or PowerPC CPU? If intel you can run VirtualBox and install windows.
Offline kazza61
« Reply #53 on: November 21, 2017, 10:47:39 pm »
How are you getting on with it? Iím finding it good for getting some art work but it doesnít provide anything for episodes. For folders I rename the poster to folder and then it works. Text description doesnít work as it comes in nfo format which the X3D canít read. Is there a way to change this to xml? Or to convert the nfo files to xml? If I could crack that bit Iíd be really happy as I find I can work it much better than TVrename.
Offline jacou031
« Reply #54 on: November 30, 2017, 12:13:44 am »
Hey Jer1956
finally do you think there is any chance that the issue with the scraper could be fixed? I check this topic each day hoping to have a good news but...  :-\
This super media reader  misses  one of its major advantage.
Thank for your informations
« Reply #55 on: December 03, 2017, 11:02:36 am »
Hey Jer1956
I asked for a progress update. The job is being squeezed in when time is free by the coding subcontractor. This code was always free. There is no revenue stream now for Sanji, only retailers with two year old stock.
No fixes to the November build problems have been released.
Offline jacou031
« Reply #56 on: December 03, 2017, 05:35:09 pm »
toooo baaad.
thank you jer
still hoping for a light in our darkness however
« Reply #57 on: December 04, 2017, 08:20:50 pm »
TV Series scraping from tvdb has been fixed on the X3D Series :)
Please follow this procedure before you scan TV Series
1. Delete all xml files in a TV Series where you had added episodes that had no images
2. Delete all zero sized jpg images in TV Series where the image did not show
3. Reboot the Mede8er and it will automatically update the scraper app
4. Scrape TV Series in the normal way
Offline kazza61
« Reply #58 on: December 04, 2017, 10:21:07 pm »
Let me be the first to say.....THANK YOU!!!!
Offline Cinoche
« Reply #59 on: December 05, 2017, 11:04:50 am »
Does this apply to all versions of the firmware or must one have the latest 4.0.2 beta installed please?
