Author Topic: Logon Failed  (Read 489 times)
Offline hverh
Logon Failed
« on: August 07, 2017, 02:49:31 pm »
I have two Mede8er MED1000X3D connected to the same network, configured the same way.
One of them, F/W 4.0.2 now has "logon failed" when I want to connect to my network, the other F/W 4.0.0
connects OK.
The network config is exactly the same for both devices.(My shortcuts, etc). I suspect it must be an internal hardware problem since it used to connect and now has that connection problem although the setup has not been changed.
Your would be greatly appreciated
Re: Logon Failed
« Reply #1 on: August 09, 2017, 07:56:22 pm »
Have you give the second a differnt Network Host name? You canlt have two called X3D.
