Author Topic: MEDE8ER 500 CRASED  (Read 2223 times)
Offline Ghostbusters
MEDE8ER 500 CRASED
« on: July 12, 2017, 11:09:20 am »
Hello
Mede8er 500x work normally just now stands the logo and can not do anything to him. Can not even update do firmware do not have any realistic? Please help me work :(
Re: MEDE8ER 500 CRASED
« Reply #1 on: July 12, 2017, 02:09:15 pm »
Connect using the yellow composite. That may clear the hdmi. If not, connect using yellow composite again, and install the firmware again.
« Reply #2 on: July 12, 2017, 08:22:48 pm »
Please do not understand which yellow compositions, I am trying to update via usb contact
« Reply #3 on: July 13, 2017, 09:38:39 am »
The player can hang trying to transfer the HDMI EDID on boot, thus not getting to the firmware update stage. You have to bypass the edid trasfer by not using hdmi.
« Reply #5 on: July 14, 2017, 11:19:11 am »
Can not even that way :(
Offline TifKag
  • X2 Skin Designer
« Reply #6 on: July 15, 2017, 02:18:20 pm »
Do NOT use HDMI cable to TV, But use Yellow connection to TV
« Reply #7 on: July 15, 2017, 05:23:47 pm »
I tried and with a yellow cable the same thing happens nothing reacts.
« Reply #8 on: July 16, 2017, 11:13:24 am »
So you have tried Energency Install of the firmware with a usb memory stick which worked before?
« Reply #9 on: July 16, 2017, 07:53:41 pm »
Yes, it worked normally before, and the player just frozen and did not show anything except the image logo
« Reply #10 on: July 17, 2017, 07:59:44 am »
No, i mean have you ever done emergency install before? It has issues of it's own. You can't fix the firmware using the installer in the main code. It has never worked.
« Reply #11 on: July 18, 2017, 02:22:24 pm »
I worked five years ago and everything worked great, just frozen with the logo and nothing else
« Reply #12 on: July 18, 2017, 05:29:22 pm »
Please confirm. Have you ever upgraded the firmware before?
« Reply #13 on: July 18, 2017, 05:43:06 pm »
yes
« Reply #14 on: July 22, 2017, 01:52:57 pm »
What to do with this player does not help
