Author Topic: MED250X only playing audio on some mkv files  (Read 1379 times)
Offline Marc Schaum
« on: July 10, 2017, 09:45:15 am »
The same mkv files do play on the PC with VLC player!
Anyone out there having the same problem, please assist.
« Last Edit: July 10, 2017, 09:50:35 am by Marc Schaum »
Offline bradford
Re: MED250X only playing audio on some mkv files
« Reply #1 on: April 19, 2018, 10:24:50 am »
I know the topic is a bit old but I also have the same problem.
Any advise?
« Reply #2 on: April 20, 2018, 07:22:25 am »
MKV is just a package. Realtek treat all packages as just containers for streams, streams which must have embedded data. The chips don't really play files. VLC is happy to use, and fix, any package data to make a file play. You can try using mkvtoolnix to remux the mkv. That in it self can add missing stream data. Otherwise you have to put it in by hand when you use it.
