Author Topic: Windows 10 Home does not recognize the mede8er500x2, most times ....  (Read 1377 times)
Offline PietParel
Hi There,
My new Acer laptop windows 10 Home does not recognize the mede8er500x2, most times.
And sometimes it does, for a while. And quits after 10 minutes or so.
And sometimes I hear the beep when I plug in the 500x2, some more bleeps, to no avail.
I installed the W10 Creation update, no difference, alas.
I ran the troubleshooter diagnostics, it says there are no issues.
As I use the 500x2 as my backup device it is rather anoying. I'm not sure what has been backed-up what not.
Appreciate your thoughts and comments
Pieter
Offline TifKag
  • X2 Skin Designer
Offline PietParel
Re: Windows 10 Home does not recognize the mede8er500x2, most times ....
« Reply #2 on: April 23, 2017, 08:45:26 am »
Thanks,
I checked both posts and got the USB ejecter.
Unfortunately I don't come to the point where I need it.
Most times when I connect the mede8er my laptop recognises it as a hard drive.
The USB ejecter recognises it too.
When I try to backup my pc to the mede8er, or when I play a movie from the mede8er, after a few minutes the connection fails. As if the mede8er disconnects.
If I retry connection is re-established and lasts half a minute or so.
This is on my new laptop.
On my old laptop the med8er takes a minute or two to connect, and the connection remains as long as I like.
Curious to learn more,
Pieter
Offline PietParel
« Reply #3 on: April 23, 2017, 08:48:32 am »
By the way I use the latest 'stable' version firmware, 3.**.
A bit reluctant tot install the beta's that came out later.
Offline TifKag
  • X2 Skin Designer
« Reply #4 on: April 23, 2017, 01:53:22 pm »
Sorry...Can't help you with that, i sold my 500X2, 2 years ago.
And bought a 800X3D.
Try to google "mede8er and windows 10", there are enough results !
« Last Edit: April 23, 2017, 01:59:27 pm by TifKag »
