Author Topic: Y2M - YAMJ solved ! working version release + Snapshot 2017.02.28.1909  (Read 7685 times)
Offline leftygt
works perfectly, thanks.... ;D ;D ;D
Offline sphinc70
Thanks Gabriele, you're a Champion. Works perfectly and super fast.
Cheers.
Offline Gabriele Giuseppini
Glad to hear it's working fine!
Offline Lancito
  • Helpful Contribution Status: +0/-3
Re: Y2M - YAMJ solved ! working version release + Snapshot 2017.02.28.1909
« Reply #18 on: October 26, 2018, 01:40:54 pm »
Java updated today and I now get errors when getting posters some are incomplete.
Anyone knows a fix?
Offline Lancito
« Reply #19 on: October 26, 2018, 01:43:29 pm »
Hi everybody,
There is a new version of Y2M edited version Snapshot 2017.02.28.1909,
fixed problem missing pisctures , fanart etc.   ;)
https://ulozto.net/!NFWaA9fvQMuR/yamj-y2m-mede8er-2-0-5-version-2-10-snapshot-2017-02-28-1909-working-rar?_fid=vy53#_ga=1.238479168.1142944073.1483100680
Hi RAYJAY. can you update this to make use of the latest Java? Thanks.
Offline elton-77
« Reply #20 on: October 26, 2018, 06:32:07 pm »
I've updated to the latest version of Java and YAMJ works fine.
Just tested it on 2 movies, Oceans Eight and Lara Croft and the returns were fine. Re-tested on a load of Marvel films and also good results.
Offline c.perras
« Reply #21 on: November 12, 2018, 02:39:04 am »
I attempted to install Y2M but there was no YAMJ skin available in step 7.5.  It was a blank window and would not allow anything to be typed into it.  Subsequently Y2M would not run. I have the latest version of Java and am running Microsoft Net Framework 4.5.  Any ideas on what could be wrong?
Offline elton-77
« Reply #22 on: November 12, 2018, 09:16:40 am »
Clearly something went wrong with the installation. I would delete what's installed and try it again.
Edit
Just noticed the version you're trying. There is another later release of YAMJ at this thread: http://www.mede8erforum.com/index.php/topic,19516.0.html
Suggest you delete the installation you've done and try this instead ... it works very well.
Offline c.perras
« Reply #23 on: November 17, 2018, 03:17:39 am »
Still having the same issues.  The link you gave me to the latest version of YAMJ had the same files I had originally and I am still having the same issue.
Offline c.perras
« Reply #24 on: November 17, 2018, 03:18:55 am »
I did uninstall all the files and reload them as you instructed but it didn't help.
Offline c.perras
« Reply #25 on: November 17, 2018, 03:34:18 am »
I got it working!!!.   I noticed that someone was having issues and restarting the computer after installation fixed it so I tried that and it worked.  Wonderful.  Now I can fix all my bad "about.jpg" files that the Mede8er has been making lately.  Thanks for your help.
Offline elton-77
« Reply #26 on: November 17, 2018, 08:37:34 am »
Glad you got it working :)
