Author Topic: Y2M - YAMJ solved ! working version release + Snapshot 2017.02.28.1909  (Read 11547 times)
Offline RAYJAY
Hi everybody,
There is a new version of Y2M edited version Snapshot 2017.02.28.1909,
fixed problem missing pisctures , fanart etc.   ;)
https://ulozto.net/!NFWaA9fvQMuR/yamj-y2m-mede8er-2-0-5-version-2-10-snapshot-2017-02-28-1909-working-rar?_fid=vy53#_ga=1.238479168.1142944073.1483100680
« Last Edit: March 12, 2017, 02:57:10 PM by RAYJAY »
Offline elton-77
Yes indeed.
Just did a newly installed YAMJ on my Windows 10 PC and it works a treat. No Java issues at all, no corrupted IMDB scores and no character set anomalies.
Great find. Thanks RAYJAY :D
Offline reevesy
yeah great mate...works a treat
...finally someone with the knowledge has bothered their arse to sort it out
 ;D
Offline RAYJAY
. . . you're welcome   ;)
Offline monkeywash
Nice one  ;)
Offline kpanago
Re: Y2M - YAMJ solved ! working version release + Snapshot 2017.02.28.1909
« Reply #5 on: October 12, 2017, 09:18:30 PM »
Hi everybody.
This sounded as good news to me, initially. I installed the new Y2M software in my PC (win 7 x 64) after having enabled the incorporated to the win 7  .NET framework 3.5, & downloaded the .NET 4.7 & the latest java runtime environment 8u131. Subsequently, I set the YAMJ settings & tried to run it to scrape a movie. I got some error messages about the "java not being recognized" & found out that they were caused by the automatic update of "the path of the environmental variables" that was done during the installation of the new java update that did not point to the java.exe folder. The errors were overcome by manually changing the necessary entry of the path in the environmental variables, so that it pointed to the exact folder that included the java.exe. After that, the Y2M worked perfectly, delivering perfect movie scrapings, but when I plugged the external HDD to my Mede8er 500X2 that runs on 3.0.4 software version, I found out that it could not generate the plot & the directors/actors part of the "about slide" for all the movies scraped with the 2017 Y2M software. At the same time, all the movies that were scraped with the previous Y2M software (when it used to work correctly), still work fine in the 500X2 as far as the said issue is concerned. Any suggestions?
Offline tonylogin
« Reply #6 on: January 28, 2018, 07:58:27 AM »
Hi There
Any other link for download please?
Regards
Mede8er 500X
Firmware: 4Beta5
PC: Win 7 Home Premuin
Offline TifKag
  • X2 Skin Designer
« Reply #7 on: January 29, 2018, 03:56:47 PM »
Why....The link works just fine !!!
Offline tonylogin
« Reply #8 on: February 01, 2018, 05:46:22 PM »
Slow download just pays adds, does not download anything.
Mede8er 500X
Firmware: 4Beta5
Offline kerveros40
Today 2018-05-03 Yamj has stopped scrape Plot for any movie i tried! Anybody knows if something can fix it?
Thank you!
Offline HCRAB
Hello,
I have the same problem. installed the latest release Snapshot 2017.02?28.1909. But it doesn't work.
is this the end of the Videowall? since there are no reactions anymore.
Thanks, a loyal user since the beginning.
Offline Chattie777
I have also tried everything but for some or other reason the Plot stays blank. What i did was to use the xml and edit that with the plot from IMDB and it works. See link below, just scroll down to point 9
http://www.mede8er.com/mede8er_y2m_user_guide_V2.05a.html
Offline HCRAB
hello,this is what i do aswell, not only for the plot but also for the name , director, casts and rating.But in the beginning the link with IMDB worked fine and no errors that you need to manage with the XML editor.
Since this looks like as a software problem in the YAMJ, my question remains.
Is there somebody in the mede8er team that will handle this issue.
screen copy attached.
