Author Topic: Med250X Software update failed  (Read 908 times)
Offline lanzo
« on: February 06, 2017, 07:34:58 pm »
Hi.
Please need help, tried to update my Mede8er.
After about an hour the thing just froze on 20 percent. Unplugged it, and now it does not want to do anything! Is there any way to reset the thing?
« Last Edit: February 07, 2017, 08:21:41 am by lanzo »
Re: Med250X Software update failed
« Reply #1 on: February 07, 2017, 08:37:43 am »
install firmware using Emergency Install.
Offline lanzo
« Reply #2 on: February 07, 2017, 09:34:13 am »
Thank you, but how does one do that?
Offline lanzo
« Reply #3 on: February 07, 2017, 09:53:41 am »
Thanks man, figured it out. Used another memory stick and all good.
