Author Topic: Very bad stuttering playing movies  (Read 19424 times)
Offline Graham N
« on: December 07, 2016, 09:45:12 PM »
I have a QNAP TS-453A with two 6TB WD red drives. I don't know what the raid setting is called but i am using it as maximum capacity.
The stuttering started after I had a message saying the drive was full. I checked and it still has 1.something free space and I deleted some films I didn't want.
Can anyone suggest any tests I can do to get to the bottom of it. I have tried so far is playing via NFS and ethernet.
Thanks for any help
Graham
Re: Very bad stuttering playing movies
« Reply #1 on: December 08, 2016, 10:54:54 AM »
Are you trying to play the movies you loaded just before it said it was full? They will be heavily fragmented, and deleting old files won't get rid of that. You must defrag the raid build.
Offline Graham N
« Reply #2 on: December 09, 2016, 06:50:20 PM »
Thanks for the reply. I believe old movies that did play as well as the new ones are stuttering. I will try a couple more and report back
