Author Topic: Image problem V4.0.2 - 6April2016 - MED1000X3D  (Read 12207 times)
Offline DeathCharge
« on: November 15, 2016, 06:43:53 PM »
Image problem V4.0.2 - 6April2016 - Beta -X3D Series - MED1000X3D
Hi guys,
I installed the new firmware today V4.0.2 (V4.0.3) and downgraded once more to X3D_Series_V4.0.0_2Jan_2015. This due to the reason that every illustration (image, photo) don't play fullscreen on my tv screen. V4.0 has no problem with this whatsoever. It varies from camera files to plain simple media files in format .jpg/jpeg or .bmp. The thumbnails no issues on all versions.
Another thingie is, which I do not encounter on V4.0, is that the hdmi source switches on and off on a irregular basis.
Did do a search on the forum, couldn't find the answer. Apologies if I overlooked.
Re: Image problem V4.0.2 - 6April2016 - MED1000X3D
« Reply #1 on: November 15, 2016, 07:07:15 PM »
That sounds like Auto Refresh changing to HD. TV's only autofill the screen with SD material.
« Reply #2 on: November 18, 2016, 04:25:23 PM »
Offline Pasiocave
« Reply #3 on: January 14, 2019, 07:53:52 AM »
It is considered to be understandable that it cannot be used.
