Author Topic: Download subtitles is not working !!! Help.  (Read 41459 times)
Re: Download subtitles is not working !!! Help.
« Reply #15 on: October 28, 2016, 10:40:03 am »
Where are the movies hosted? I have issues when using my hard drive, but not with NFS. I am going to use Slave Mode to check for issurs on the drive.
I used slave mode and ran disktools. Now it is "finding" subs. So the issue is the list itself is a temp file which you pick from. If that can't be created becuase of storage issues it won't work.
« Last Edit: October 28, 2016, 11:28:23 am by jer1956 »
Offline tmeulenm
« Reply #16 on: October 28, 2016, 03:46:40 pm »
I have the same problem. few days ago everything is working fine en now it won't find any subtitles.
If I download it myself and place it on the hard drive, the mede8er recognizes it.
Does anybody know how to fix it.
« Reply #17 on: October 28, 2016, 04:18:24 pm »
So do you slave mode to copy them off a PC? The act of ending slave mode can cause issues.
Offline Joco1114
Re: Download subtitles is not wokingiak !!! Help.
« Reply #18 on: October 28, 2016, 04:43:02 pm »
I have spoken with guys at opensubtitles. They have changed things in API and they will contact with mede8er staff soon. I hope it will really soon. We have to be patient.
J
« Reply #19 on: October 28, 2016, 04:46:39 pm »
It is working. There are two issues. If you can't create files, you can't create the list. The list itself is now filtered more severely by opensubs.  This means try adding the release year manually, with a space, after the name in the search.
« Last Edit: October 28, 2016, 05:54:05 pm by jer1956 »
Offline YyyNnn
  • Helpful Contribution Status: +3/-12
« Reply #20 on: October 28, 2016, 06:01:30 pm »
Thanks. Waiting for results.
Offline Joco1114
« Reply #21 on: October 30, 2016, 07:08:04 am »
Yes, it seems you are right. It search only for specific releaser found in filename. But this way we lost the similar releasers. For example Dimension - LOL, NhaNc3 - Saints, etc. But the year never appear in the filename (for me): Supergirl.S02E03.720p.HDTV.X264-DIMENSION.mkv.
Offline livevil
« Reply #22 on: October 30, 2016, 10:49:51 am »
I also have the same problem, starting several days ago. I thought it was a DNS problem at first since I got no results at all (and the request seemed to end very quickly)
But for several files, I was able to get the subs by manually adding the season or the releaser for example. However the player is not able to find the subtitles everytime (even when I'm sure they are present on opensubtitles.org). Plus manual editing on the remote control is kinda pain in the a**.
I hope there will be a fix soon!
Offline YyyNnn
« Reply #23 on: October 31, 2016, 07:33:09 am »
yes. the same here... waiting for your fix !!!  :(
Offline blaze
  • Helpful Contribution Status: +1/-14
« Reply #24 on: October 31, 2016, 09:30:48 pm »
I am also struggling with this for a few days now  :-\
I can not download or find any subtitles, even if I edit the name manually etc.
Can we get a fix for this?    Finding and downloading subtitles is one of my favorite MED service :)  8)
« Reply #25 on: November 01, 2016, 08:39:17 am »
We have made opensubs aware that "their" recent change has made search unusable. They  have made a change which should take a day or so to start processing the requests.
Offline blaze
« Reply #26 on: November 01, 2016, 08:42:00 am »
Thats great, Jer!
So everything should be back to normal in 24-48 hrs?
In the meantime is there any workaround?  Changing name in the search box or so ?  I could not get any results so far, no hits no matter what I try  :-\  :'(
Offline YyyNnn
« Reply #27 on: November 01, 2016, 09:47:23 am »
Great !!! Thanks
« Reply #28 on: November 01, 2016, 10:30:43 am »
Only you guys can decide if what changes is good enough. We will pass on your general view.
Offline blaze
« Reply #29 on: November 01, 2016, 11:06:52 am »
To be able to search again I think they should go back to the initial settings, we have been using before.
If we have to manually edit names, it will be very time consuming.
So I guess either we fix a new FW according to their needs, or they go back to their previous settings for search....  ;)
