Author Topic: Download subtitles is not working !!! Help.  (Read 67147 times)
Offline YyyNnn
  • Helpful Contribution Status: +3/-12
« on: October 25, 2016, 04:04:50 PM »
For 2 days i cant download any subtiles. Please help !!!
Offline Joco1114
Re: Download subtitles is not working !!! Help.
« Reply #1 on: October 26, 2016, 02:01:11 PM »
Same here. It seems there is a problem with the servers of opensubtitles.org, or they changed API again. If they change API, we need a new firmware. :(
Offline guy1717
« Reply #2 on: October 26, 2016, 02:57:46 PM »
yep, same problem here
Offline neo_2011
  • B8a Tester - X3D NET API
« Reply #3 on: October 26, 2016, 11:52:44 PM »
Same here.
Offline YyyNnn
« Reply #4 on: October 27, 2016, 12:21:47 PM »
Offline rockdude176
« Reply #5 on: October 27, 2016, 02:54:48 PM »
I tried to download subtitles on a couple of movies today. I did not find any problems yet.
Offline Jeremy
« Reply #6 on: October 27, 2016, 03:19:10 PM »
No problem found on this side, maybe a temporaty issue on the webservers from opensubtitles.org?
If so, it seems to be solved already
that's the way the cookie crumbles
Offline YyyNnn
« Reply #7 on: October 27, 2016, 04:10:48 PM »
Sorry. But still nothing is working. Cant download any subtitle for any movie . Helpppppp
« Reply #8 on: October 27, 2016, 04:49:00 PM »
Change your DNS setting in Network Setup. Are you still using 127.0.0.1?
Offline YyyNnn
« Reply #9 on: October 27, 2016, 05:20:45 PM »
To which dns ? What is the ip number ?
Offline Joco1114
« Reply #10 on: October 27, 2016, 05:44:19 PM »
It worked so far, DNS and IP settings are good, according to my router. I've tried DHCP and Fix IP too, internet services (youtube, flicker, web etc.) are working correctly. So, the problem is exists as I mention before. :(
Offline YyyNnn
« Reply #11 on: October 27, 2016, 05:47:29 PM »
Same here !!! only subtiltles are not working. Scraps andyoutube is working fine. I used 8.8.8.8 and local dns, but still nothing is changed. Cant download subs !!!
Offline theophilos
« Reply #12 on: October 27, 2016, 06:25:55 PM »
Same problem here!
Sent from my iPhone using Tapatalk
« Reply #13 on: October 27, 2016, 09:05:25 PM »
You could just be suffering from the fact the api dosn't filter subtitle packing formats. The website does. So you pick a format by accident that the player can't unpack.
Offline YyyNnn
« Reply #14 on: October 28, 2016, 04:37:58 AM »
all the formats are not working. subtitles that i download 4 days ago, i cant download again...
something is wrong with downloading subs for sure !!!
