Oke jer1956,
Thanks for your reply.
I don't no what to do with your comment for me that is aba cadabra . I just wanted to tell that the trailers play just sometimes, after scraping you can't even test if the trailer wil play and if it is the correct one, because in 95 percent of the time it will not play.
I tested the trailer link's on my laptop, and they allso do not play there ( sometimes there will play one)
