Author Topic: Med500x2 upgrade  (Read 1083 times)
Offline V
Med500x2 upgrade
« on: October 06, 2016, 06:19:08 am »
HI
I have a Med500x2 version 2.04 software.
I am trying to do an upgrade and software update but the unit will not respond.
My Med is networked but can not stream from another PC on the network.
Can see the other networked machines but when I try access is gives me a login fail.
I have created user accounts on the PC ( windows 7 )( where all my movies and data is stored )
I have shared the drives
I have set permission levels to read and write.
If I install a HD in my Med I can view and access it from my PC and create a folder in the HD on the MED , but I can not access the other way round.
Been struggling 3 days now.
Realy frustrated.
Can anyone please help or give me some fress ideas.
Regards V
Offline SigSauer
Re: Med500x2 upgrade
« Reply #1 on: December 10, 2016, 11:10:09 pm »
Did you disable sharing with passwords in the advanced network sertings on your pc?
