Author Topic: Sound Mute coming from Mede8er 250-Different to mute on Remote  (Read 6057 times)
Offline topgun_za_1
« on: September 24, 2016, 09:33:44 PM »
Hi There, I have had my Mede8er 250x for 5-6 years now and no problem ever, till now.
A mute speaker appears on my TV from the Mede8er 250x box and cuts off the sound. It is not the same mute as on the remote control.
Help please!
I tried updating firmware to latest version, it does'nt help.
See attached picture.
Mant Thanks
Re: Sound Mute coming from Mede8er 250-Different to mute on Remote
« Reply #1 on: September 27, 2016, 09:45:38 PM »
Looking at the icon - it looks more an overlay icon from your TV.
Check the manual of your TV - maybe some mute set on some HDMI port setting menu?
Offline topgun_za_1
« Reply #2 on: September 28, 2016, 07:44:55 AM »
Hi Thanks for your prompt reply. It is definitely not from the TV. When I pull out the power cable of the Mede8er from the wall socket and plug it in after +/-20secs it works ok for a while.
« Reply #3 on: September 28, 2016, 09:11:59 AM »
Have you bought a new TV and left control over hdmi on?
