Author Topic: 400x2 Scraper doesn't work anymore *SOLVED*  (Read 1014 times)
Offline Tokfan
« on: August 16, 2016, 06:34:58 am »
Hi there,
Solved it! :)
http://www.mede8erforum.com/index.php/topic,16159.msg105543.html#msg105543
I'm not sure if the problem showed up after installing v.3 firmware, but I suspect as much.  :-[
When I scan the folder in favourites it says "Scan in progress" for maybe 10 seceonds and then ends. It haven't found any of the new movies.
Folders are write enabled and no "moviename.xml" are in the folders. I do however have a view.xml in some of the folders? All old folders with "moviename.xml" I can see in the jukebox.
Any suggestions what I can do to fix this?
Movie folders are named after med8ers suggestions.
Folders are write enabled.
They are stored on a buffalo nas.
« Last Edit: August 16, 2016, 07:35:01 am by Tokfan »
