Author Topic: Network icon missing  (Read 1684 times)
Offline Lucsi
« on: April 09, 2016, 07:31:38 pm »
Hello all
I'm using  meder 400x2s v3.0.5 update
After a reboot my network icon from media library missing
I tried a reset and a reboot but same issue
Many thanks for any tips
Lucsi
  • Helpful Contribution Status: +190/-53
Re: Network icon missing
« Reply #1 on: April 12, 2016, 08:32:24 am »
Did you install using Emergency Install? Setup Install is not reliable once Sanji make their modifications to code.
Offline Lucsi
« Reply #2 on: April 12, 2016, 08:48:08 am »
Hi
Thank YOU
I  downlowed The File 3.0.5 and put it on USB started meder hold On Off Buton FOR 20 second than install started. When completed mede8er starts all ok but no network icon beside the shortcut icon
Many thanks
« Reply #3 on: April 12, 2016, 09:46:18 am »
Did you get the Initial Setup for Clock, Network?
Offline Lucsi
« Reply #4 on: April 12, 2016, 09:51:57 am »
Yes all setup completed time time zone network all no issues
Offline Lucsi
« Reply #5 on: April 12, 2016, 04:11:31 pm »
Hello for your help
Still missing the network icon anything else I can do here
Is any other link for fw upgrade download ?
Many thanks
Offline Lucsi
« Reply #6 on: April 12, 2016, 05:54:37 pm »
Hello all
Problem solved by reinstalling fw 3.0.4 than upgrade back to 3.0.5 sorted the issue with missing network icon
Best regards
