Author Topic: Feedback for - V4.0.2 - 4March2016 - Beta -X3D Series - for MED1000X3D/MED800X3  (Read 21165 times)
Offline adi1
  • Helpful Contribution Status: +0/-4
I Have a big request.
Is it possible to create subtitles with black box background in exchange subtitles, for example, blue or green. It is very necessary for the subtitle Hardcoded.
example
Regards
Offline mike_carton
  • Helpful Contribution Status: +13/-1
"Setup --> Misc ---> Auto Detect Decoding"
What does this do?
What does this do?
This is for auto detecting subtitle encoding like ANSI or UTF8 - mainly used in Asian countries.
Offline daltimor
Hi everyone.
Just update my 800x3 and trailer don't work? I have icon in the corner on tv but after pressing it nothing happen. I added trailer do JUKE+ after updates but the picture is black. Any idea? Thanks
Re Subtitle 'Search' not working
http://www.opensubtitles.org/
Site will be online soon. We are doing some necessary backups and upgrades. Thanks for understanding.
Edit Back online  :)
« Last Edit: March 06, 2016, 10:54:16 AM by Mede8er1 »
Offline TifKag
  • X2 Skin Designer
Hi everyone.
Please do some searching in this forum before posting a question, and you will find out YouTube has changed their coding, and Mede6er is looking into a new provider for Trailers.
Offline polakis
Hello.
The last couple of months i have a scrapper different function-problem, not like it used to work. The normal scrapping function was that you could scan every folder (movies, tv series, documentaries). After the latest updates you cant scan them anymore. You dont have the option of scanning in every folder. You can scan only the initial folder of your external disk. Besides that, the problem starts after scanning the main folder. All the files disappear and nothing is displayed. You need to remove the hard drive and put it back again in order to see all of your files again! Is this a general function after the latest updates, or is it only my problem?
Offline dxer
There is a bug for series background image. When you delete episode, just after this episodes are reloaded and background image of this series is removed/replaced with default bluish background image.
I have latest beta firmware.
Offline daltimor
So you saying I bought player which says on the box trailer function but they actually don't work??? Its like buying new car but the 4th gear don't work >:(
Something is not right then  >:( >:( >:( >:(
I know you tube change coding but that is not good enough
Spe115
  • Guest
The firmware is Work in progress, it's not working yet, but will be in a while.
Saying the player does'nt Work is a bit overreacted as it is only the trailer function that is not working at the moment. And if you had read other topics about this, then you would have known the fix is being tested already.
Be patience please as these things take time.
Best regards,
Spe115
Offline Fan234
Since installing this new Beta firmware I have a problem with scrapping movies. It works for awhile then freezes and I have to remove power and boot up again. This has happened a couple of times and is a new fault.
Offline daltimor
Best regards,
Spe115
Sure I should be more patient  ;)
Thanks for help
Spe115
  • Guest
You're very welcome :), happy to help out where I can.
Offline helmi
There is still a bug in the firmware.
When you watch a movie from an usb-hd, pause or stop it and the screensaver turns on (hds are in sleep mode), you can't switch off the med1000x3d.
I tried a reset of the confg, but it didn't fix the problem.
