Author Topic: IMDB rating not working correctly  (Read 4581 times)
Offline Seamus MCL
« on: February 22, 2016, 11:50:15 am »
Hi All,
           I've been using http://www.mede8er.org/Firmware_Final/Y2M/YAMJ_To_Mede8er_Peter_Butler_V2.0.5mod_Shizzl_yamj2.10-r3763.zip for quite a while no successfully with no issues. However I've recently run into problems whereby the IMBB rating is reported as -0.1/10 , no other issues are effected (ie: artwork , description, etc) all work fine . Has anybody else seen this issue or even better a solution ?. I've not changed anything on the machine doing this activity (ie: no java version change, config changes etc), I've also attached an example.
Regards & thanks
Seamus
Offline sphinc70
Re: IMDB rating not working correctly
« Reply #1 on: February 23, 2016, 08:27:21 am »
Hi Seamus,
I have added a comment under the thread 'edit rating' which provides a solution of sorts.
Regards
Sphinc70
Offline gmusteric
« Reply #2 on: March 01, 2016, 10:02:03 pm »
In YAMJ settings, under IMdB, set full.info to TRUE.
Then scan and rating will be as on IMdB.
Offline OldskoolOrion
  • I like Pi !
« Reply #3 on: March 01, 2016, 11:37:53 pm »
Hi Seamus,
If that doesn't do the trick, check my reply in this post :
http://www.mede8erforum.com/index.php/topic,17241.0.html
Alphamale on betablockers !
Offline Treken
« Reply #4 on: March 02, 2016, 01:54:29 pm »
Did not work...
Offline Buff
« Reply #5 on: March 15, 2016, 04:18:52 am »
Any Solution guys? I'm having same issue.
Offline Treken
« Reply #6 on: March 27, 2016, 05:01:14 am »
It's been close to 2 weeks and still no solution from what others said to try and failed to fix...
I am still hoping that there will be a solution to this, as others are as well...
Offline DrPaul
« Reply #7 on: November 12, 2016, 09:04:30 am »
I found that using the 2.10-SNAPSHOT version of YAMJ fixed things...
yamj-2.10-SNAPSHOT-2016-08-27-1843-87b0f8a-bin to be precise which is when I downloaded it.
I've had endless issues with my Win7 VM on my Mac which is why I have taken so long to post this reply.
Offline Lancito
  • Helpful Contribution Status: +0/-3
« Reply #8 on: November 29, 2016, 11:53:37 pm »
Where do you get this YAMJ version?
« Reply #9 on: November 30, 2016, 08:49:30 am »
Yamj is opensource and hosted on github
https://github.com/yamj/yamj-v2
The players version should be classed as a fork, and hosted there as well.
If taking a module from one to fix the other works, that package of modules also should be hosted on github.
