Author Topic: [Tip] Emulate DMR using normal UPNP file access (PC server)  (Read 17290 times)
« on: January 13, 2016, 05:39:19 PM »
Later models have a DMR, Digital Media Renderer. This allows you to use the player as dumb device and select what you want to play remotely, and push it to the player from a client device such as a phone or tablet.
http://www.mede8erforum.com/index.php/topic,17286.0.html
That tip also describes how to pull the stream in via normal UPNP. So once setup you select what you want at he source end, which is what DMR is all about.
« Last Edit: January 21, 2016, 07:36:41 PM by jer1956 »
