Hi, community
I'm French and I use Google Translate to write to you, bear with me please
I'm the proud owner of a MED8ER1000X3D goal I have some questions and especially a major concern for the EDIT function for TV series ...
First, I have a 4TB MyBook external hard drive from Western Digital. When I disconnected as indicated with F2 and I connect it to my PC, it asks for a file analysis as if the hard drive was disconnected suddenly
. Why ?
Yet I have no Linux partition on the hard drive ... It would be nice to indicate on the MED8ER that the hard drive is indeed disconnected, right?
Similarly, if I do not the parameter MED8ER FAVOURITES on the launch of the machine, there is no way of knowing if it is ready unless we support regularly OK to know. Would an indication not possible please ?
Secondly, I appreciate very much the choice of wallpapers for favourite folders but it is possible to add a BROWSE function to choose your own wallpaper from the hard disk?
Finally, on the EDIT function for TV series ... Since the last update (4.0.2), the MED8ER crashes every time I want to edit a series, even when I scan the entire file
I tried with another hard drive but nothing happens
. I use THE RENAMER program that uses the site TheTVDB.com. Anyway, it worked very well this update ...
Can you tell me if a new update is expected to address this issue please ?
Hoping to have been clear, thank you for your understanding
Also thank you for your availability and monitoring devices
D.
