Author Topic: Feedback for - V4.0.2 - 7Nov2015 X3D Series  (Read 77618 times)
Offline eentje
Re: Feedback for - V4.0.2 - 7Nov2015 X3D Series
« Reply #30 on: December 01, 2015, 01:09:49 PM »
For those who don't use the internal scraper of the Mede8ers, does anyone know how to set thumbgen to generate proper trailer links to the new Movie Trailers sites?  Where is this linking to?
Haven't installed yet, just checking in beforehand.
i use thumbgen for the movie about.jpgs. After u created them u can just add trailers from the mede8er itself. Thumbgen cant generate the links itself. And as u might have noticed thumbgen is eol(end of life) and is not being updated anymore so dont expect such a feature in the future :)
« Last Edit: December 02, 2015, 09:10:49 AM by Mede8er1 »
www.thetvdb.com contributor
Offline adamforeman
« Reply #31 on: December 01, 2015, 08:15:51 PM »
Dear Devs
I have just removed all the files eg xml, jpg's etc and just re-scraped my movies. The T for Trailers appears top right but when I click it, a black screen appears and then displays the play window with graphics BUT it doesnt play the trailer. It just stops.
Please see attached screenshots
Cheers
« Last Edit: December 02, 2015, 09:10:58 AM by Mede8er1 »
« Reply #32 on: December 01, 2015, 09:05:44 PM »
Dear Devs
Cheers
Please read the function description on the firmware download post. Change the Trailer Timeout setting.
« Last Edit: December 02, 2015, 09:11:07 AM by Mede8er1 »
Offline chelsea4023
« Reply #33 on: December 01, 2015, 10:32:29 PM »
Hi jer1956,
Thanks for the pointer, I will check my settings. I assume it's as easy as that.
Thank you for the quick reply.
Chris
« Last Edit: December 02, 2015, 09:11:15 AM by Mede8er1 »
Offline chelsea4023
« Reply #34 on: December 02, 2015, 12:47:21 AM »
Problem solved, thanks to jer1956.
Chris
« Last Edit: December 02, 2015, 09:11:24 AM by Mede8er1 »
Offline adamforeman
« Reply #35 on: December 02, 2015, 09:33:47 AM »
Unfortunately, changing the setting to either one of the 10 second settings just gives me a black screen now. Not even getting the original play trailer screen.
Any ideas?
Cheers
Sent from my SM-N910F using Tapatalk
« Reply #36 on: December 02, 2015, 09:52:52 AM »
Any ideas?
Cheers
It may  be a symptom of the general issue of stale DNS after a firmware upgrade.   Try powering cycling everything on the LAN, and experiment with a different DNS server IP in the players setup.
Offline JuniorClass
« Reply #37 on: December 02, 2015, 10:07:56 AM »
for the trailer i finally manage get it to work locally
i notice that the trailer icon displayed anyway even if there is no trailer presented .
also the trailer doesn't support mkv  . i use mp4 instead .
there is only one thing i might not get it right the naming for the trailer . what is the best way .
MovieName-trailer.ext        i used this one based on what member said here in forum
Offline chelsea4023
« Reply #38 on: December 03, 2015, 12:40:05 PM »
Hi jer1956,
please can you send me a link to the post "Change the Trailer Timeout setting", as I must be blind as a bat and cannot find it. I even did a 'search' for it and all I get is your reference to it. Sorry to be a pain, but I am getting the same problem as others. I loaded 4.02, scraped all my movies and then went to favourites and added trailers. Now when I try to get a film trailer, the word loading (in blue) appears in the top left hand corner of the screen and following that a small blue question mark, but no trailer (I set the trailer timeout to 10 seconds).
Chris
p.s. I did change to jukebox mode to get three rows of movie jpg's per screen.
Offline wecpc
« Reply #39 on: December 03, 2015, 01:40:46 PM »
I too have a problem with the latest firmware update. I loaded 4.02, scraped all my movies and then went to favorites and added trailers. Now when I try to get a film trailer, the word loading (in blue) appears in the top left hand corner of the screen briefly and then just a blank screen, I do not even get the play icon as others appear to get. I have tried setting the trailer timeout to 10 seconds and I have even down a complete power down of my network to clear any stale DNS problems. Everything else works fine including Youtube and all the internet options on the Mede8er.
So as I appear to not be the only one with this problem, then you have a problem with the update.
« Last Edit: December 03, 2015, 02:17:01 PM by wecpc »
« Reply #40 on: December 03, 2015, 02:50:32 PM »
There is some issue with Safari playing trailers. We have asked the trailer host site why.
Offline wecpc
« Reply #41 on: December 03, 2015, 03:49:16 PM »
I do not see how Safari is the cause of my problem as I am streaming from my Windows Home Server V1.0. Before the recent problem with trailers, due to YouTube changes, I used to be able to use the trailer function perfectly, not that I have used it much anyway and now I cannot anyway. To me it is no great loss, but I thought I had better mention the problem I have which might help other users and for Mede8er to hopefully fix it.
« Reply #42 on: December 03, 2015, 07:37:08 PM »
The old Youtube xml segment is now ignored. You would have to mod the new xml segment to point at a local trailer server.
Offline wecpc
« Reply #43 on: December 04, 2015, 02:32:09 PM »
I have no idea what you are talking about and how to do it, so I will not bother, but thanks for your help anyway.
« Reply #44 on: December 05, 2015, 06:04:41 PM »
Local trailer and extras does not work on the jukebox+ (aggregated jukebox).
When it is fixed?
One solution for aggregation and local trailers is to create a local trailer server on the Network.  I have checked that the concept still works with the new trailer xml.  Tools to automate its creation where requested via Wanted!, but it didn't raise any interest.
